Using chtMultiregionSimpleFoam solver in OpenFoam v2012 in Linux
Old   April 2, 2023, 07:01
Post Using chtMultiregionSimpleFoam solver in OpenFoam v2012 in Linux
US
Trojan1804 is on a distinguished road
Hello All,
I want to use chtMultiregionSimpleFoam solver in Openfoam v2012 Can anyone share the command to install and use this solver in OpenFoam v2012 Linux or any other way to do so.
I was trying to install the dependencies from the below link:
https://www.cemf.ir/how-to-install-o...ack-on-ubuntu/
In installing the pre-requisites section in the above website, the following lines of code are not running:
sudo apt-get install flex libfl-dev libreadline-dev zlib1g-dev openmpi-bin libopenmpi-dev mpi-default-bin mpi-default-dev
sudo apt-get install libgmp-dev libmpfr-dev libmpc-dev bison libncurses-dev libxt-dev
sudo apt-get install libscotch-dev libptscotch-dev libfftw3-dev libboost-system-dev libboost-thread-dev libcgal-dev
sudo apt-get install qt4-dev-tools libqt4-dev libqt4-opengl-dev freeglut3-dev libqtwebkit-dev.
Trojan1804 is offline   Reply With Quote
Old   April 3, 2023, 05:02
Yann
Yann will become famous soon enoughYann will become famous soon enough
Your question is pretty unclear.
chtMultiregionSimpleFoam is one of the solver in OpenFOAM-v2012. If you installed OpenFOAM-v2012 you already have chtMultiregionSimpleFoam available.
You can have a look at the corresponding tutorials: $FOAM_TUTORIALS/heatTransfer/chtMultiRegionSimpleFoam/
If you are new to OpenFOAM, I strongly suggest you to start with basic tutorials to understand how OpenFOAM works before moving to chtMultiregionSimpleFoam simulations, which are a bit more complex to setup due to the multiregion aspect.
Have fun,
Yann
Yann is offline   Reply With Quote
Old   April 3, 2023, 05:56
US
Hi Yann,
Can you please check the updated post?
Old   April 3, 2023, 06:17
Yann
Originally Posted by Trojan1804 View Post
Hello All,
What do you mean by this? It is not possible to help you if you don't give details about the issue you are facing.
How to give enough info to get help
What OS are you using?
Is there any reason for you to follow this exact installation tutorial?
If not, you can go for precompiled versions, which would avoid to install all the prerequisite stuff: https://develop.openfoam.com/Develop...s/precompiled/
sudo apt-get install openfoam2012-default
Yann
How to import the results of one solver to the other solver in OpenFOAM ngodinhnhan OpenFOAM 2 April 17, 2020 02:25
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Sharing links for two phase solver packages developed by openfoam community swap_9068 OpenFOAM Programming & Development 1 April 2, 2017 06:43
How to rewrite a standard OpenFOAM solver as a C++ class cfbaptista OpenFOAM Programming & Development 7 March 23, 2016 05:50
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
