Best solver for multiphase pipe flow?
Old   March 30, 2023, 10:00
Default Best solver for multiphase pipe flow?
riccardo
ricx is on a distinguished road
Hello everyone, I am new to this forum. I am trying to simulate a twophase pipe flow, which is the best solver to use. Ideally I would like to have compressible solver with one phase dispersed in the other. The problem is that with twophaseeulerfoam I am not able to arrive to convergence. Any suggestions?
ricx is offline   Reply With Quote
Old   April 10, 2023, 11:00
Humberto
humber11 is on a distinguished road
I believe that 'twophaseEulerFoam' is recommended for this, but there is also 'compressibleInterFoam'.
A list of how solvers work:
https://www.openfoam.com/documentati...ommand%20line.
humber11 is offline   Reply With Quote
Old   May 17, 2023, 05:24
Josh Williams
joshwilliams is on a distinguished road
For dispersed two-phase flows, you could use a Lagrangian approach. One suitable solver appears to be sprayFoam, which has a compressible transport model for the fluid. I guess it will account for chemical reactions and species transport, but these could probably be turned off.
For Eulerian approach you could use twoPhaseEulerFoam which is described as "Solver for a system of two compressible fluid phases with one dispersed phase"
joshwilliams is offline   Reply With Quote
Old   May 17, 2023, 05:26
Josh Williams
I would not recommend an interFoam based solver. It is very computationally expensive to resolve the interface between phases, and from my experience it can cause difficulties in converging the continuity error.
multiphase, pipe flow, solvers, twophaseeulerfoam
CPUs vs GPUs for CFD? hami11 Hardware 22 July 23, 2024 16:59
unable to run dynamic mesh(6dof) and wave UDF shedo Fluent UDF and Scheme Programming 0 July 1, 2022 18:22
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 09:36
