Annular flume simulation:how to edit two rotating cell zones in dynamicMeshDict?
Old   March 22, 2023, 04:01
Smile Annular flume simulation:how to edit two rotating cell zones in dynamicMeshDict?
mil tang
csj1246957849 is on a distinguished road
Dear Foamers,
I'm using OF v9 multiSolidBodyMotionSolver for simulating the annular flume, what I want to do is simulate the sheer ring and annular flume spin at the same time, I referred to what OpenFOAM wiki suggested in section 2.8 multiMotion:https://openfoamwiki.net/index.php/P...sh#multiMotion.
Following what wiki suggested, I setup the dynamicMeshDict as follows, which has been modified slightly in OF v9 style.
code:
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolver multiSolidBodyMotionSolver;
solidBodyMotionFunction multiMotion;
upper_rotation;
solidBodyMotionFunction rotatingMotion;
rotatingMotionCoeffs
origin (0 0 0);
axis (0 0 1);
omega 3.86; // rad/s
bottom_rotation;
origin (0 0 0);
axis (0 0 1);
omega -1; // rad/s
then I run pimpleFoam and I found that the Kurang number is completely 0, which looks like the shear ring and the sink are completely stationary and not rotating at the speed I set. Could you please tell me why this happens and how do I set it correctly
File Type: txt code1.txt (638 Bytes, 0 views)
csj1246957849 is offline   Reply With Quote
ofv9 multimotion
Cell Zones Recognition Problem Maralady FLUENT 0 June 19, 2013 15:00
Help with Cell Zones Maralady FLUENT 0 June 19, 2013 00:39
Multiple urf settings on different cell zones ReeKo Fluent UDF and Scheme Programming 1 March 13, 2012 09:20
[Other] how to extract cell zones by cgnsToFoam Ohbuchi OpenFOAM Meshing & Mesh Conversion 0 July 22, 2010 05:19
Tracking/Modifying Cell Zones Greg Perkins FLUENT 1 November 7, 2000 00:35
