March 19, 2023, 14:35 |
How to compute CD and CL values on OpenFOAM?
Adityan Rajesh
Heyy everyone, I am still a beginner on OpenFOAM.
I actually wanted to do a simulation of NACA0012 at an angle of 4 degrees, under a Reynolds Number of 2 million. I first Simulated it using ANSYS Fluent, wherein I got the CL value at 0.44 CD value at 0.0088 These results were kinda within the range, with the CD value slightly off, most likely that the SA model overpredicts drag. But on OpenFOAM, I don't know why, I get my CL value at only 0.23, instead of 0.44. The temperature is 293K, viscosity at 1.71e-5 and rho at 1.25. Velocity at around 51.4 m/s Can anyone help me out on the files, shared here. U FILE: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (51.3417 3.5901 0.0000); boundaryField { inlet { type freestreamVelocity; freestreamValue $internalField; } outlet { type freestreamVelocity; freestreamValue $internalField; } airfoil { type noSlip; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type freestreamPressure; freestreamValue uniform 0; } outlet { type freestreamPressure; freestreamValue uniform 0; } airfoil { type zeroGradient; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 1.7157857e-5; boundaryField { inlet { type freestream; freestreamValue $internalField; } outlet { type freestream; freestreamValue $internalField; } airfoil { type nutUSpaldingWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 6.863143119e-5; boundaryField { inlet { type freestream; freestreamValue $internalField; } outlet { type freestream; freestreamValue $internalField; } airfoil { type fixedValue; value uniform 0; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 500; deltaT 1; writeControl timeStep; writeInterval 10; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { momErr { type momentumError; libs (fieldFunctionObjects); executeControl writeTime; writeControl writeTime; } contErr { type div; libs (fieldFunctionObjects); field phi; executeControl writeTime; writeControl writeTime; } turbulenceFields1 { type turbulenceFields; libs (fieldFunctionObjects); fields ( k epsilon nut nuEff R devReff L I ); executeControl writeTime; writeControl writeTime; } mag1 { type mag; libs (fieldFunctionObjects); field turbulenceProperties:R; result magR; executeControl writeTime; writeControl writeTime; } forceCoeffs1 { type forceCoeffs; libs ("libforces.so"); patches (airfoil); p p; U U; rho rhoInf; rhoInf 1.25; pRef 0; porosity no; writeFields yes; CofR (0.05334 0 0); liftDir (-0.06975647374412530077595883519414 0.99756405025982424761316268064426 0); dragDir (0.99756405025982424761316268064426 0.06975647374412530077595883519414 0); pitchAxis (0 0 1); magUInf 51.46714; lRef 0.5334; Aref 0.5334; outputControl timeStep; outputInterval 500; } } // ************************************************************************* // |
