chkMultiRegionFoam
Old   March 16, 2023, 08:12
Default chkMultiRegionFoam
sidemountyucatan is on a distinguished road
I try the first time chkMultiRegionFoam with a simple example. Two circular fluid bodies separated by a pipe (as you find it in an double jacket heat exchanger), flow in different directions and one fluid transfer heat ,through the separting piece of pipe, to the other. Now I try to figure out the T boundary in the 0-folder.
There is one patch fluidint_to_pipe and I do not know which would be the suitable condition for that. I didn't find any tutorial aswell which I could take as a template.
Can somebody give me a hint how to proceed ?
Thx a lot.
Marcus
sidemountyucatan is offline   Reply With Quote
Old   March 16, 2023, 09:58
Yann
Yann will become famous soon enoughYann will become famous soon enough
Region interfaces usually use one of the following boundary conditions for T:
  • compressible::turbulentTemperatureCoupledBaffleMix ed;
  • compressible::turbulentTemperatureRadCoupledMixed;
Depending on the version you are using, you can run some of the chtMultiRegionFoam tutorials to have examples :
Regards,
Yann
Yann is offline   Reply With Quote
