Cannot find patchField entry for AMI
Old   March 16, 2023, 04:54
Default [SOLVED] Cannot find patchField entry for AMI
gart04 is on a distinguished road
*** OpenFoam 9 / Ubuntu ***
Hi
I'm having troubles with an AMI simulation (a simple FAN in a fluid). I run a parallel PimpleFoam and i obtain this message :
--> FOAM FATAL IO ERROR:
file: /home/nico/OpenFOAM/nico-9/run/CE-MOD1-AMI-V1/0/T/boundaryField from line 25 to line 55.
    From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184.
FOAM exiting
My Mesh is Ok (I use SNAPPY and i check the quality with checkMesh and the different patch on Paraview), and my AMI patches are in the T file as below :
|  \\    /   O peration     | Version:  9                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 275;
boundaryField
    inlet
        type        fixedValue;
        value       uniform 275;
    outlet
        type        zeroGradient;
    walls
        type        fixedValue;
        value       uniform 275;
    fan
        type        fixedValue;
        value       uniform 500;
    AMI1
        type            cyclicAMI;
        value           uniform 275;
    AMI2
        type            cyclicAMI;
        value           uniform 275;
I use Baffles to create AM1 and AMI2 :
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createBafflesDict;
internalFacesOnly true;
baffles
    baffleFaces
        type        faceZone;
        zoneName    rotatingZone;
        patches
            master
                name            AMI1;
                type            cyclicAMI;
                matchTolerance  0.0001;
                neighbourPatch  AMI2;
                transform       none;
            slave
                $master;
                name            AMI2;
                neighbourPatch  AMI1;
I really don't understand if someone can help, after the patchfield entry error for AMI i have the following error for the 16 processors, but i assume it's the result of the first error :
[0] --> FOAM FATAL ERROR:
[0] cannot find file "/home/nico/OpenFOAM/nico-9/run/CE-MOD1-AMI-V1/processor0/0/p"
[0]
[0]     From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
[0]     in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line [14]
[14]
[14] --> FOAM FATAL ERROR:
[14] cannot find file "/home/nico/OpenFOAM/nico-9/run/CE-MOD1-AMI-V1/processor14/0/p"
[14]
[14]     From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
[14]     in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 539.
[14]
FOAM parallel run exiting
Thanks a lot
gart04 is offline   Reply With Quote
Old   March 17, 2023, 03:35
Hi
I found my pb if it can help somebody :
I see in the mesh log that my baffleFaces did not convert faces into boundary faces in patches.
In the snappyhexmesh i had a faceType boundary which block the patches creation. I suppress the line and the solver run, with another problems ...
refinementSurfaces
         AMI
             level (2 2); // Note: better: levels 3 3
             faceType boundary;
             cellZone rotatingZone;
             faceZone rotatingZone;
             cellZoneInside inside;
         fan{ level (2 4);} // Note: better: levels 3 3
         outlet{ level (0 0);}
         inlet{ level (0 0);}
         walls{ level (1 1);}
Best regards,
[snappyHexMesh] Cannot find patchField entry for *** mbox97 OpenFOAM Meshing & Mesh Conversion 2 November 25, 2021 11:06
Cannot find patchField entry for InletWall range_rover OpenFOAM Running, Solving & CFD 5 November 18, 2020 22:21
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 hconel OpenFOAM Pre-Processing 0 October 5, 2018 18:22
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
