Calculation of forces and moments acting on a wing in OpenFOAM.
Old   February 21, 2023, 15:31
Default Calculation of forces and moments acting on a wing in OpenFOAM.
puck1 is on a distinguished road
I need to perform calculations of the forces and moments acting on a wing using the computational package OpenFOAM. The wing moves with a sideslip angle and is vertically oriented. The inclination is carried out along a line rotated 30 degrees to the vector of the oncoming flow. The angle of attack of the wing is given in the figure. The inclination angle in the vertical plane varies from -10 to +20 degrees. It is necessary to find the longitudinal and transverse components of force and moment, relative to the vertical axis passing through the lower point of rotation of the wing. Two variants should be considered in the calculation: a flat plate and a curved wing, bent according to the NACA0010 profile.
Could you help me with her solution? I will be very grateful for your help.
puck1 is offline   Reply With Quote
Old   May 11, 2024, 07:54
Default relative to the vertical axis passing through the lower point of rotation of the win
[QUOTE=puck1;844952]It is necessary to find the longitudinal and transverse components of force and moment, relative to the vertical axis passing through the lower point of rotation of the wing.
openfoam
Forces, moments and torque calculation foamiste OpenFOAM Post-Processing 5 October 7, 2022 05:16
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
Forces and Moments Given by forces Function Object are not Perpendicular Ship Designer OpenFOAM Post-Processing 1 February 7, 2022 00:32
Residuals and forces spiraling out of control before failing edomalley1 OpenFOAM Running, Solving & CFD 3 September 7, 2018 11:42
Forces calculated by OpenFoam very strange tta223 OpenFOAM Post-Processing 3 August 5, 2017 10:10
