How to get the 6-DOF motion in openfoam_v1806?
Old   February 19, 2023, 23:05
Default How to get the 6-DOF motion in openfoam_v1806?
Yanning Chen
Brandon_ is on a distinguished road
Hello,everyone:
I am using openfoam_v1806 to run calculations related to floating bodies, and added anchor chain calculations to the floating bodies (this part uses the moody library on github). Due to the limitation of the anchor chain library, I can only use the rigidbodymotion solver instead of the sixdofrigidbodymotion solver to calculate, which leads to no center of mass in the openfoam log file, as shown below. I would like to know how to extract the six degrees of freedom motion of the floating body in this situation? Post-processing or what kind of functions are added to the controlDict? My files are attached.
Thanks in advance.I really need your help,
Brandon
File Type: txt log.txt (353 Bytes, 7 views)
Brandon_ is offline   Reply With Quote
Old   October 18, 2023, 02:54
liyuchao
ouc_ycl is on a distinguished road
Can you help me or guide me how to couple openFoam and API of Moody.
ouc_ycl is offline   Reply With Quote
6-dof rigid motion, rigidbodymotion, sixdofrigidbodymotio
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
External management of solid motion (using dynamicmesh) maxou1993 Main CFD Forum 0 July 28, 2015 12:37
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
coupled motion using six dof udf but with restraints fluentuser2003 Fluent UDF and Scheme Programming 0 September 4, 2012 16:51
Force can not converge colopolo CFX 13 October 4, 2011 23:03
