Fixed Temperature Constraint problems for coal combustion
Old   February 16, 2023, 02:00
Talking Fixed Temperature Constraint problems for coal combustion
Yaniel Garcia Lovella
yglovella is on a distinguished road
Hi everybody
I am trying to adapt simplifiedSiwek tutorial case to a pulverized coal combustion application. But, after setting up everything I got the following error. I am using OpenFOAM/9-foss-2021a in a HPC facility.
Any help will be appreciated
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 9
\\/ M anipulation |
Build : 9
Exec : reactingFoam -parallel
Date : Feb 16 2023
Time : 05:49:52
Host : "nodo20.uclv.hpc.cu"
PID : 69404
I/O : uncollated
Case : /users/uclv_yanielg/CRIEPI_Jet_Flame_Burner
nProcs : 4
Slaves :
3
"nodo20.uclv.hpc.cu.69405"
"nodo20.uclv.hpc.cu.69406"
"nodo20.uclv.hpc.cu.69407"
Pstream initialised with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
type heRhoThermo;
mixture multiComponentMixture;
transport sutherland;
thermo janaf;
energy sensibleEnthalpy;
equationOfState perfectGas;
specie specie;
Reading field U
Creating turbulence model.
Selecting turbulence model type LES
Selecting LES turbulence model kEqn
Selecting LES delta type cubeRootVol
bounding k, min: 0 max: 2e-05 average: 0
LES
model kEqn;
turbulence on;
printCoeffs on;
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
PrandtlCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Cdelta 0.158;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Aplus 26;
Cdelta 0.158;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Ce 1.048;
Ck 0.094;
Creating thermophysical transport model
Selecting thermophysical transport type LES
Selecting default LES thermophysical transport model unityLewisEddyDiffusivity
Creating reaction model
Selecting combustion model PaSR
Selecting chemistry solver
solver ode;
method standard;
standardChemistryModel: Number of species = 6 and reactions = 2
Selecting ODE solver seulex
using integrated reaction rate
Creating field dpdt
Creating field kinetic energy K
No MRF models present
Creating fvModels from "constant/fvModels"
Selecting finite volume model type buoyancyForce
Selecting finite volume model type clouds
Selecting parcelCloud reactingMultiphaseCloud
Constructing particle forces
Selecting particle force sphereDrag
Selecting particle force gravity
Constructing cloud functions
none
Constructing particle injection models
Creating injector: model1
Selecting injection model manualInjection
Constructing 3-D injection
Selecting distribution model RosinRammler
Distribution min: 5e-06 max: 0.0005 mean: 5e-05
Selecting dispersion model stochasticDispersionRAS
Selecting patch interaction model standardWallInteraction
Selecting stochastic collision model none
Selecting surface film model none
Selecting U integration scheme Euler
Creating component thermo properties:
liquids - 1 components
solids - 3 components
Selecting heat transfer model RanzMarshall
Selecting composition model singleMixtureFraction
Selecting T integration scheme analytical
Selecting phase change model liquidEvaporation
Participating liquid species:
H2O
Selecting devolatilisation model constantRateDevolatilisation
Participating volatile species:
CH4: particle mass fraction = 0.127444
H2: particle mass fraction = 0.020889
CO2: particle mass fraction = 0.062667
Selecting surface reaction model COxidationKineticDiffusionLimitedRate
C(s): particle mass fraction = 0.659000048
Selecting parcelCloud thermoCloud
none
Distribution min: 5e-06 max: 0.000565 mean: 4.8e-05
Selecting composition model singlePhaseMixture
Selecting finite volume model type radiation
Selecting radiationModel P1
Selecting absorptionEmissionModel binary
Selecting absorptionEmissionModel constant
Selecting absorptionEmissionModel cloud
Selecting scatterModel cloud
Creating fvConstraints from "system/fvConstraints"
Selecting finite volume constraint type fixedTemperatureConstraint
- selecting cells using cellSet ignitionCells
- selected 1 cell(s) with volume 2.681904768e-12
[3] #0 Foam::error:rintStack(Foam::Ostream&)[0] #0 Foam::error:rintStack(Foam::Ostream&)[1] #0 Foam::error:rintStack(Foam::Ostream&)[2] #0 Foam::error:rintStack(Foam::Ostream&)[1676526618.105599] [nodo20:69406:0] ib_md.c:1161 UCX WARN IB: ibv_fork_init() was disabled or failed, yet a fork() has been issued.
[1676526618.105637] [nodo20:69406:0] ib_md.c:1162 UCX WARN IB: data corruption might occur when using registered memory.
yglovella is offline   Reply With Quote
Weird temperature at the outer wall in combustion chamber omichalo121 FLUENT 5 September 19, 2022 05:21
Difference between convective heat transfer and fixed temperature jpina FLUENT 4 March 14, 2016 09:22
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Fixed temperature for domain seojaho CFX 8 June 4, 2009 14:21
Fixed Temperature in StarCCM+ Oliver Siemens 4 September 8, 2008 08:22
