Dynamic Mode Decomposition (STDMD) application |
February 2, 2023, 02:11 |
serg
Rep Power: 11 |
I have a rather large LES case, which I’d like to postprocess it via DMD. The domain consists of ~340M hex cells, and I have no problem with solving it in parallel. Since it is not possible to post process it after the final solution (and reconstructing the domain takes too long between the time steps), I decided it’d best to perform run-time DMD. My plan is to apply it at some specific cutting plane as a starting point, however, quick research suggested that it can only be applied to regions, boundaries etc. Is there any way to perform DMD on a cutting plane? There is a tutorial, and it maps the solution onto a coarser one, but, I believe it might be problematic when running in parallel. Any suggestions are appreciated. Regards. S. Last edited by kont87; February 2, 2023 at 02:16. Reason: Grammar |
February 5, 2023, 05:35 |
#2 | |
serg
Rep Power: 11 |
Is there any way to distribute/decompose a blockMesh region onto already decomposed domain? Regards. |
March 23, 2023, 03:52 |
mhy
Hello, If you have solved this problem, could you please give detailed information about the solution?
March 23, 2023, 04:45 |
serg
Rep Power: 11 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
Error in compute process - No Active Application | yetlyg | FLUENT | 8 | October 27, 2018 23:30 |
Parallel computing error using multiple nodes | Jingxue Wang | OpenFOAM Running, Solving & CFD | 11 | January 14, 2018 11:51 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 12:52 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
