IBM method for rhoPimpleFoam
Old   January 20, 2023, 09:41
Default IBM method for rhoPimpleFoam
Tiziano Santese
t.santese is on a distinguished road
Hello everyone,
I would like to ask, has anyone succesfully used the immerse-boundary-conditions toolkit from prof. Jasak with rhoPimpleFoam?
I am trying to modify the solver following the SOLVER_COOKBOOK, however i guess that for compressible solvers there is some more work to do.
I solved all the error message I got until now, but then my solver starts and stop without error message in the first iteration, when it reaches the rhoEqn.H.
Note: I am using openfoam-ext4.0 and all the tutorials run smoothly.
Starting from the tutorial "PitzDailyTurbulentsimpleIbFoam" I did all the modifications to the case, and then run it with my new solver.
I guess my solver is even working correctly since compiles with no errors, but I may have some wrong setting in the case files (BCs, or controlDict)..
This is the output from the terminal:
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 50 corrector loops
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
Creating field DpDt
Internal flow
Number of IB cells: 524
Create immersed boundary cell mask
Create immersed boundary face mask
Found immersed boundary patch 0 named pitzDailyIB
Starting time loop
Courant Number mean: 480453 max: 3.23475e+06 velocity magnitude: 35351.5
Creating minMaxField for field p
Creating minMaxField for field U
Creating maxFieldCell for field epsilon
Creating minMaxField for field rho
t.santese is offline   Reply With Quote
ibm, immersed boundary method, rhopimplefoam
Unstructured Grid VS. Levet Set method VS. Immersed Boundary method aerosjc Main CFD Forum 5 November 29, 2022 21:23
Harmonic balance method for calculating multi-stage turbines HIT19B902072 SU2 2 April 24, 2022 02:31
Vortex Panel Method Rafaelle55 Main CFD Forum 1 December 17, 2018 11:16
Finite element method ANSYS CFX tomd97 CFX 2 April 4, 2018 05:10
Lattice Boltzmann method vs Finite Element Method and Finite Volume Method solemnpriest Main CFD Forum 3 August 12, 2013 12:00
