snappyHexMesh and blockMesh not creating mesh in correct region.
Old   January 19, 2023, 11:37
Default snappyHexMesh and blockMesh not creating mesh in correct region.
Aaditya
aadicfd is on a distinguished road
Hello, I created a simple model of cylindrical container to perform heat transfer simulation using FreeCAD for CAD modelling. I exported the model in stl format along with domain boundaries and faces. I have attached all the files here.
I have been trying to mesh the container domain. I am using cyclic blockMesh first to create a hex cylindrical block. Next I am using surfaceFeatures and snappyHexMesh to mesh the region inside the cylindrical container. To generate mesh in correct region I located a point using paraview that was clearly within the region where I want the mesh.
However, when I check the mesh in paraview, the mesh is generated for wrong region.
I tried different point locations but the result turns out to be the same.
I have attached the outputs of snappy and blockmesh as well.
Could someone help me understand why am I having this problem and how to solve it. Is it a bug in snappyHexMesh?
Thank you.
File Type: jpg Screenshot from 2023-01-19 13-50-15.jpg (103.7 KB, 11 views)
aadicfd is offline   Reply With Quote
blockmesh, meshing 3d, openfoam 9, paraview, snappyhexmesh
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 10:26
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
[snappyHexMesh] Creating multi region mesh for chtMultiregionFoam tclph OpenFOAM Meshing & Mesh Conversion 1 December 8, 2020 16:25
Error when solving p_rgh bob94 OpenFOAM 0 March 17, 2020 09:12
[Gmsh] gMsh instead of blockMesh for base mesh, then snappyHexMesh sazabi2001 OpenFOAM Meshing & Mesh Conversion 0 February 23, 2017 13:00
