How to make the file of KinematicLookupTableInjection rereadable? |
Huan Zhang
Rep Power: 5 ![]() |
Dear all,
I would like to extend this thread here, Adapt InjectionModel #9 How can I make the injectors reread the file of KinematicLookupTableInjection in constant folder at each time step? Because I set a criterion about when the particles should be injected, there may be different particle numbers and properties at each time step. Right now I can rewrite the particle properties in KinematicLookupTableInjection at each time step, but the injectors just read this file at the start of run. How can I make the injectors reread it at each time step? I really appreciate your help! Jasper |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
