Change Mesh/Object Geometry
Old   January 9, 2023, 12:21
Default Change Mesh/Object Geometry
Manuel Zeitler
ZeitM is on a distinguished road
I have a question regarding body motion/modification within a simulation.
I have a problem where I would like to solve a fluid simulation while a object inside changes drasticaly. I also have meshes for each timestep the simulation should be solved. Is there a way that these meshes are used for their specific time steps? If I simply put them inside the according timestep directory they are ignored. I also face the problem that the meshes don't have the same cell count.
I would like to not use the mapFields command every single time step as this would take a lot of extra time.
Thanks in advance for every response to my problem.
ZeitM is offline   Reply With Quote
body motion, dynamic boundary, mesh adaptation
how to use DEFINE_GEOM to change the geometry with time? dengdeng Fluent UDF and Scheme Programming 2 September 13, 2018 10:06
[ICEM] For the geometry change lnk ANSYS Meshing & Geometry 2 July 16, 2012 17:01
How can I change view to geometry in FLUENT John FLUENT 2 June 25, 2007 08:54
Restarted run and change in geometry...question Vanessa CFX 3 August 28, 2006 08:55
Geometry setup for phase change problem Fred G. Kang Main CFD Forum 1 October 14, 1998 12:41
