December 31, 2022, 08:53 |
SOWFA installation and first tutorial run
ijaz fazil
Rep Power: 13 |
Our team intends to conduct CFD assessments of wind turbine wake aerodynamics. Previously, we utilized ANSYS FLUENT; we now want to use SOWFA. We are familiar with OpenFOAM but not with SOWFA.
Based on https://github.com/pablo-benito/SOWFA-installation, we installed SOWFA. In the final part under "Runtime configuration," it was said that we must export all libraries to the LD_LIBRARY_PATH. When I run this comment “${LD_LIBRARY_PATH}”, I get this error “No such file or directory” Also, when I try to run the example case “/example.ABL.flatTerrain.neutral” I get this error “./runscript.preprocess ./runscript.preprocess: line 79: /home/yusuffuzail/.bash_profile: No such file or directory ./runscript.preprocess: line 80: OpenFOAM-2.4.x: command not found -Renumbering the mesh with renumberMesh... -Decomposing the domain with decomposePar... -Checking the mesh with checkMesh...” Can you please help me in fixing this issue or troubleshoot this error? |
May 28, 2023, 23:49 |
Hello, now I have also encountered this problem, please tell me that you have solved it, thank you very much
August 18, 2023, 10:34 |
hello,Have you solved this problem?I will really appreciate it if you can have any repies.
fluent, openfoam, sowfa, ubuntu, wind turbine |
