Turbulence flow and heat flux budgets for LES / DNS in an OpenFOAM solver |
December 21, 2022, 17:07 |
priyesh kakka
Rep Power: 8 |
Hi all,
I created an utility to calculate LES / DNS flow and heatflux budgets in OpenFOAM. The solver calculates required variables or the fly (instantaneous) and then the means of these variables can be used to calculate various terms such as "production", "dissipation" etc . There is also a post-processing tool which will calculate all these terms for you and you just have to then plot wherever you want them in the entire field. There is a test case for the tutorial too! I created this in OpenFOAM v6 3 years back but now making it opensource. We have published a couple of papers with this solver so the code is validated. Here is the github link for the code: https://github.com/kakkapriyesh/Turb...ts-in-OpenFOAM Let me know if you have any questions and I hope this is helpful to the community. Priyesh |
budgets, dns, les simulation, openfoam, turbulence analysis |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
