Question about parallel processing
Old   December 20, 2022, 12:28
Default Question about parallel processing
Chris
cegan09 is on a distinguished road
I hope it's ok to ask here, the question relates to a few portions of the process, so I didn't know which sub section to throw it in.
I'm new to openFOAM, just starting to wrap my head around it. I have my setup successfully splitting a job up to run on multiple CPU cores through the decomposeParDict configuration. However, I had hoped this would allow me to run two simulations at the same time by assigning each of them half my cores and it doesn't seem to work that way. My virtual machine has 24 cores assigned, I have 16 running the first job, and when I try to run the second job with 8 cores, it seems to just pick cores 0-7 and overlap with the job assigned cores 0-15.
I have searched, but not had much luck finding an answer. Is there a way to specify the cores I want each job to use? Meaning is there a way to force the second job to use Cores 16-23?
If I missed the answer somewhere obvious I apologize.
Also, I know my example above doesn't evenly split the cores between the two jobs. I'd assigned 16 when verifying that the simulations even run, and now I'm just trying to figure out the part of running both at once.
cegan09 is offline   Reply With Quote
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 09:25
Parallel Processing by region Swift OpenFOAM Running, Solving & CFD 0 July 30, 2015 08:42
Parallel processing in quad core Renato Pacheco FLUENT 1 June 4, 2008 12:06
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 05:08
FEDORA CORE and PARALLEL processing Tuks CFX 2 August 20, 2005 11:05
