December 15, 2022, 13:47 |
BlueCFD-Core 2020 mpiexec error 1726
H. C.
Rep Power: 3 |
Thank you for reading! I'm a Blue-CFD user. Currently, I'm trying to run a multi process job using command "mpiexec" I input "mpiexec -np 12 simpleFoam -parallel" and received error information as below: $ mpiexec -np 12 simpleFoam -parallel ERROR: Failed to post close command error 1726 ERROR: unable to tear down the job tree. exiting... However, if I remove "-parallel", the simulation could run. Could anyone please help me by telling me how I should use mpiexec command in Blue-CFD correctly? BTW, I'm using Windows10 with MSMPI 10.1. Thank you in advance! |
Workbench 2020 R1 Issue (Core Dumped) $Mono_Prefix/bin/mono | chissene | FLUENT | 1 | May 30, 2022 04:12 |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 12:36 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
