Increasing viscosity increases courant number for some reason. |
December 1, 2022, 19:29 |
david simm
The folder is attached, when the viscosity is 0.001 the simulation runs perffectly fine, but if you change it to 0.01, courant number shoots up for some reason. even though it becomes more laminar (from 1000 re at 0.001 viscosity to 100 re at 0.01 viscosity). You can see that its in pimplefoam, but i did have this on icofoam before aswell, with the same issue.
courant number increasing, decreasing, viscosity, viscosity decreasing |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
