Javier
Rep Power: 3 ![]() |
Hi
I am running openFoam-9. I manged to run a serial simulation. When I try to run in parallel, I get this message "Cannot find patchField entry for Submarine2.stl" in every "/processorN/0/p/boundaryField" entry. The /0/p file is as follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $pressure; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" inlet { type zeroGradient; } outlet { type fixedValue; value $internalField; } lowerWall { type zeroGradient; } upperWall { type zeroGradient; } frontAndBack { type zeroGradient; } Submarine2.stl { type zeroGradient; } #include "include/frontBackUpperPatches" } // ************************************************************************* // Thanks in advance. /Joc |
[snappyHexMesh] Cannot find patchField entry for *** | mbox97 | OpenFOAM Meshing & Mesh Conversion | 2 | November 25, 2021 10:06 |
Cannot find patchField entry for InletWall | range_rover | OpenFOAM Running, Solving & CFD | 5 | November 18, 2020 21:21 |
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 | hconel | OpenFOAM Pre-Processing | 0 | October 5, 2018 17:22 |
decomposePar fails "Cannot find patchField entry for maxY" | JasonQuinn | OpenFOAM Pre-Processing | 2 | April 4, 2017 01:07 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
