Jinghong Su
Rep Power: 5 ![]() |
I am using the type rotatingWallVelocity to simulate taylor-couette flow. Strangely, the radial velocity of the rotating wall is equal to 0, while the cells close to the rotating wall, especially the first layer cells, show abnormal radial velocities. In order to observe this phenomenon more clearly, I simulated the case where the inner and outer walls have the same angular velocity. The inlet and outlet are set to be cyclic. The front patch and back patch are set to be empty.
The magnitude of velocity image1.png The radial velocity(ur) image2.jpg The radial velocity(ur) is obtained by codes following: dimensionedVector zNormal("zNormal", dimless, vector(0.0, 0.0, 1.0)); volVectorField C = mesh.C(); volVectorField xy = (C - zNormal * (C & zNormal)); ur = U & xy / mag(xy); 0/U file Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { fixedWall { type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega constant 2.72; value uniform (0 0 0); } movingWall { type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega constant 2.72; value uniform (0 0 0); } patch1_inlet { type cyclic; } patch1_outlet { type cyclic; } patch2_periodic0 { type empty; } patch2_periodic1 { type empty; } } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear; } laplacianSchemes { default Gauss linear orthogonal; } interpolationSchemes { default linear; } snGradSchemes { default orthogonal; } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.05; } pFinal { $p; relTol 0; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; } OpenFOAM version : v2012 Beside, I also try to set the rotating velocity by codedFixedValue, finding the same results. So I think there is something wrong with the discrete format,but I can't check it out. Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { #includeEtc "caseDicts/setConstraintTypes" fixedWall { name rotatingVelocity_out; type codedFixedValue; code #{ const vector axis(0, 0, 1); const scalar omega = 2.72; vectorField v(omega*this->patch().Cf() ^ axis); operator==(v); #}; value $internalField; } movingWall { name rotatingVelocity_in; type codedFixedValue; code #{ const vector axis(0, 0, 1); const scalar omega = 2.72; vectorField v(omega*this->patch().Cf() ^ axis); operator==(v); #}; value $internalField; } patch1_inlet { type cyclic; } patch1_outlet { type cyclic; } patch2_periodic0 { type empty; } patch2_periodic1 { type empty; } } |
#2 | |
Lorenzo
Rep Power: 0 ![]() |
I have the same problem. Did you solve it? If so, what was the problem? Thanks in advance. |
icofoam, near-wall, openfoam, radial velocity, rotatingwall |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Rotating wall velocity boundary condition for axisymmetric flow problem | diwakaranant | SU2 | 1 | March 23, 2013 23:45 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
