Additional Parameter "C" for combustionProperties
Old   October 26, 2022, 06:44
Default Additional Parameter "C" for combustionProperties
Chris
dwarfgang is on a distinguished road
Hello everyone, I am a student who is quite new to using OpenFOAM.
I recently installed a custom solver called rhoReactingCentralFoam (based on OpenFOAM v7) in order to simulate one-step global combustion in a supersonic environment (H2-Air reaction).
From setting up the combustionProperties file in the constant folder (in which I chose the diffusion combustion model), the program asked me to input a scalar value for variable "C." After searching up on the internet, this was the most detailed description I could find for the parameter.
"Additional parameter C is used to distribute the heat release rate in time."
Does it mean that I have to specify the reaction's heat release rate after manual calculation?
I was able to find a correlation for the reaction rate, which was found on the thesis at the bottom of https://repository.tudelft.nl/island...8-9eda89bb04e7 (page 64, under diffusion), but still cannot exactly understand what the variable indicates.
It would be great if someone could offer a thorough explanation on what this is.
Thank you in advance!
-Chris
dwarfgang is offline   Reply With Quote
Old   December 2, 2022, 07:54
Rocco Tortorolo
rocco_Tororolo is on a distinguished road
Hi I am doing simulations in reactingFoam and i encountred the same issues.
did you find any answers?
rocco_Tororolo is offline   Reply With Quote
Old   December 15, 2022, 02:52
Chris
Unfortunately no I implemented an arbitrary value of C = 10, but it does not seem to suit supersonic combustion accurately as the concentration of H2 diminishes much slower compared to similar cases.
Will be looking further into this parameter once I am done writing my Undergrad research paper.
Old   December 16, 2022, 19:13
Ali B.
reverseila is on a distinguished road
I don't know anything about combustion...
but There are two combustion models (in $FOAM_SRC/combustionModels) that have this C parameter in them, infinitelyFastChemistry and diffusion
According to the source code, C is a private member variable of type scalar which they commented it as "Model constant"
It is read from a dictionary (not sure from where exactly but I could only find C in infinitelyFastChemistryCoeffs inside combustionProperties files of the $FOAM_TUTORIALS/combustion.)
In the source code of the above combustion models, we have something like these
// file: infinitelyFastChemistry.C
// Constructor definition
template<class ReactionThermo, class ThermoType>
void infinitelyFastChemistry<ReactionThermo, ThermoType>::correct()
    this->wFuel_ == dimensionedScalar(dimMass/dimVolume/dimTime, Zero);
    if (this->active())
        this->singleMixturePtr_->fresCorrect();
        const label fuelI = this->singleMixturePtr_->fuelIndex();
        const volScalarField& YFuel =
            this->thermo().composition().Y()[fuelI];
        const dimensionedScalar s = this->singleMixturePtr_->s();
        if (this->thermo().composition().contains("O2"))
            const volScalarField& YO2 = this->thermo().composition().Y("O2");
             // wFuel: Fuel consumption rate
            this->wFuel_ ==
                this->rho()/(this->mesh().time().deltaT()*C_)
               *min(YFuel, YO2/s.value());
// file: diffusion.C
void diffusion<ReactionThermo, ThermoType>::correct()
    if (this->active())
        if (this->thermo().composition().contains(oxidantName_))
                this->thermo().composition().Y(oxidantName_);
            this->wFuel_ ==
                C_*this->turbulence().muEff()
               *mag(fvc::grad(YFuel) & fvc::grad(YO2))
               *pos0(YFuel)*pos0(YO2);
Hope this helps!
reverseila is offline   Reply With Quote
c parameter, combustionproperties
[PyFoam] running pyFoam(Plot)Runner.py in parallel Studi OpenFOAM Community Contributions 10 September 6, 2015 17:38
Force can not converge colopolo CFX 13 October 4, 2011 23:03
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
plot additional parameter Jane Siemens 2 March 15, 2004 20:40
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
