Changing Mesh resolution of Tutorial Case Channel395 |
Tianxiong Zhao
Rep Power: 0 ![]() |
Hi, everyone. My question is basically 'Using a finer mesh resulted in a different result'.
I tried to change the resolution of mesh in the tutorial case Channel395 (pimpleFoam/LES). To be specific, I doubled the number of cell in y direction (normal to wall). After doing this, the turbulence in result disappear, the whole flow field became laminar. Is this reasonable? And does a finer mesh always mean a more accurate result? |
les, mesh, pimplefoam |
DPM results changing with CFD mesh resolution | Reza Zarghanishiraz | FLUENT | 0 | June 21, 2022 18:14 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts | a.habibi | ANSYS Meshing & Geometry | 5 | October 4, 2012 05:10 |
