How to calculate heave, sway and roll response of 2-D floating body with wave in open
Old   September 28, 2022, 00:29
Default How to calculate heave, sway and roll response of 2-D floating body with wave in open
Akshay
Akshay80 is on a distinguished road
Good Morning Everyone,
I am working on finding the heave, sway and roll response of 2-D floating body with wave in openfoam(V-5). I generate wave and it is perfect. simulations also ran without any error. Now i want to calculate the response of floating body with wave please suggest me how to do so in openfoam.
Regards,
Akshay
Akshay80 is offline   Reply With Quote
Old   September 29, 2022, 05:42
Roithamer
Roithamer is on a distinguished road
Position of your defined body is written down to solver log at each iteration. You should write a script that reads the position data in solver log and accumulate it with iteration or simulation time to plot a graph. You can use python or Linux-bash for script.
Roithamer is offline   Reply With Quote
Old   October 1, 2022, 07:24
Akshay
Dear Sir,
Thanks for your reply..! can you will explain what is the order of 6dof motions(surge, sway heave, roll, pitch, yaw) in orientation tensor.
6-DoF rigid body motion
Centre of rotation: (2 0.02 0.4)
Centre of mass: (2 0.02 0.4)
Orientation: (1 0 8.6106890225e-21 0 1 0 -8.6106890225e-21 0 1)
Linear velocity: (0 0 0)
Angular velocity: (0 1.44659575578e-17 0)
Regards,
Akshay
Old   February 27, 2024, 00:24
Ramesh Mukkund
Ramesh mukkund is on a distinguished road
hello Roithamer,
I'm also running floating obect (2d case) using olaflow. I'm able run the simulation successfully but to plot surge, heave i don't have much knoweledge in that could you share more info on this .
thanks in advance
Ramesh mukkund is offline   Reply With Quote
