Problem calculating grad(U) while adding a source term
Old   September 26, 2022, 16:19
Default Problem calculating grad(U) while adding a source term
Dimas
dimasbarile is on a distinguished road
Hi everyone! Im trying to compile a source term which uses grad(U) for the force calculation in OpenFOAM 2.4.0. For some reason the following line does not work:
volTensorField gradU = fvc::grad(U);
I saw several posts where this line is valid but when i try to compile the following error appears:
error: no matching function for call to ‘grad(const vectorField&)’
In file included from /home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.H:124:0,
                 from /home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvc.H:49,
                 from sources/derived/actuationDiskV10b_calib_Source/actuationDiskV10b_calib_SourceTemplates.C:61,
                 from sources/derived/actuationDiskV10b_calib_Source/actuationDiskV10b_calib_Source.H:374,
                 from sources/derived/actuationDiskV10b_calib_Source/actuationDiskV10b_calib_Source.C:58:
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:51:1: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad(const Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh>&)
 grad
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:51:1: note:   template argument deduction/substitution failed:
In file included from sources/derived/actuationDiskV10b_calib_Source/actuationDiskV10b_calib_Source.H:374:0,
sources/derived/actuationDiskV10b_calib_Source/actuationDiskV10b_calib_SourceTemplates.C:439:35: note:   ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ is not derived from ‘const Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh>’
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:68:1: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad(const Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> >&)
 grad
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:68:1: note:   template argument deduction/substitution failed:
sources/derived/actuationDiskV10b_calib_Source/actuationDiskV10b_calib_SourceTemplates.C:439:35: note:   ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ is not derived from ‘const Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> >’
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:91:1: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 grad
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:91:1: note:   template argument deduction/substitution failed:
sources/derived/actuationDiskV10b_calib_Source/actuationDiskV10b_calib_SourceTemplates.C:439:35: note:   ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ is not derived from ‘const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>’
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:113:1: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad(const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >&, const Foam::word&)
 grad
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:113:1: note:   template argument deduction/substitution failed:
sources/derived/actuationDiskV10b_calib_Source/actuationDiskV10b_calib_SourceTemplates.C:439:35: note:   ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ is not derived from ‘const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >’
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:142:1: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 grad
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:142:1: note:   template argument deduction/substitution failed:
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:159:1: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad(const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >&)
 grad
/home/dbarile/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvcGrad.C:159:1: note:   template argument deduction/substitution failed:
dimasbarile is offline   Reply With Quote
Old   October 6, 2022, 00:47
Tatsuya Shimizu
LongGe is on a distinguished road
Hi
The error occurs because the "U" used in your code is a vectorField.
NOTE: How to convert vectorField to volVectorField
NOTE: difference volVectorField and vectorField
Our Work: https://www.idaj.co.jp/product/ennovacfd/openfoam_gui/
Powered by Ennova : https://ennova-cfd.com/
Ennova's Channel Partners : http://www.wolfdynamics.com/
LongGe is offline   Reply With Quote
Old   October 12, 2022, 17:00
Dimas
Originally Posted by LongGe View Post
Hi
Thank you very much LongGe! Now it's working fine
grad u, no matching function, source term
Problem with coded source term for multiphaseEulerFoam shuji_type97 OpenFOAM Running, Solving & CFD 2 July 22, 2022 02:37
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
