Lagrangian particles adddition to interFoam using swak4Foam
Old   August 19, 2022, 05:43
Default Lagrangian particles adddition to interFoam using swak4Foam
scp
Baba
scp is on a distinguished road
I am trying to simulate rising of bubble in a solid-liquid suspension. For the bubble-liquid interface interFoam solver is used. Particle addition is carried out by swak4Foam. But when I am running the simulations, I am getting a warning like "No entry 'dimension' in field muField". However I am able to complete the simulations.
Should I do something?
Please help.
Thanks in advance,
Baba
scp is offline   Reply With Quote
Old   August 20, 2022, 08:34
Assistant Moderator
Bernhard Gschaider
Originally Posted by scp View Post
Please help.
Thanks in advance,
Baba
No. swak turns of dimension checking for its calculations because that would complicate things for the user (for instance: half of the numeric constants people use in expressions would need to have to have dimensions added to them. Otherwise dimension checking when adding them to a field that is not dimensionless would fail). Of course that disables one of the cool (and for the novice user annoying) features of OF: dimension checking. swak4Foam assumes that the user did the dimension checking of his expressions by hand
The expressionField function object allows the user to specify a dimension for the result post-calculation because sometimes it is used to "mock" the existence of a field for a boundary condition etc that checks for that dimension. Also: it is good practice to add that dimension to document "I checked the dimension: this is it". I rarely do this. But this only proofs what I always say "Just because I wrote swak4Foam doesn't mean that I use it properly"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 23, 2022, 02:45
scp
Baba
Thank you very much for your response.
Sincerely,
Baba
interfoam bubble, lagrangian particles, swak4foam
Radiation heating of lagrangian particles in reactingParcelFoam CHUIKOV OpenFOAM Running, Solving & CFD 0 February 28, 2021 15:53
Lagrangian Particles + Porosity 37269 OpenFOAM Running, Solving & CFD 3 September 25, 2020 05:14
Lagrangian particles injection with interFoam and swak4foam Cluap OpenFOAM Running, Solving & CFD 0 June 12, 2018 12:37
Lagrangian Data extract from sprayFoam e.g. with swak4Foam mokard OpenFOAM Post-Processing 2 January 16, 2018 04:44
Corellation dimension of lagrangian particles oswald OpenFOAM Post-Processing 0 January 27, 2016 08:30
