problem using chtMultiRegionFoam with 2 solids |
August 16, 2022, 09:10 |
Kevin Redosado
Rep Power: 4 |
Hellos everyone, I am currently trying to solve in a steady state the heat equation of 2 solids that are bounded by a fixed temperature gradient. When I try to run the solver, it says
--> FOAM FATAL ERROR: There needs to be at least one region From function static const Foam::Time& Foam:: pimpleMultiRegionControl::time(const Foam::PtrList<Foam::fvMesh>&, const Foam::PtrList<Foam::fvMesh>&) in file cfdTools/general/solutionControl/pimpleControl/pimpleMultiRegionControl/pimpleMultiRegionControl.C at line 47. FOAM exiting If I change one of the parameters to a fluid it can run it no problem but does someone know why it cannot work with 2 solids? I am trying to compare the numerical solution of this solver and thus wanted to use this simple case. Thanks in advance. I am using openFoam 9 |
chtmultiregionfoam, heat transfer |
convergence problem of steady 2D film cooling calculation using chtMultiRegionFoam | ruanyg968tf | OpenFOAM Running, Solving & CFD | 1 | April 10, 2024 02:23 |
Problem in using chtMultiRegionFoam for steady-state | mep | OpenFOAM | 4 | May 16, 2021 10:42 |
Possible bug in chtMultiRegionFoam with 2 solids in contact? | keitaro7_14 | OpenFOAM Running, Solving & CFD | 1 | February 5, 2021 13:19 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
