pyfoamPlotRunner and Watcher do not show any plots, only terminal outputs
Old   August 15, 2022, 04:21
Default pyfoamPlotRunner and Watcher do not show any plots, only terminal outputs
Marrie
manle0312 is on a distinguished road
I am running the Vortex Shedding c2 case. I run my case using the following commands:
foamCleanTutorials
fluent3DMeshesToFoam ../../../meshes_geometries/vortex_shedding/ascii.msh
checkMesh
renumberMesh -overwrite
icoFoam | tee log.icofoam
pyFoamPlotWatcher.py log.icofoam
gnuplot scripts0/plot_coeffs
paraFoam
I managed to run the case using icoFoam, plot the coefficients and visualize it using openFoam. However, I am unable to get
to show any plots.
I made sure that my simulation does have a lot of time step data (350 seconds in total, and plot_coeffs do have a lot of time data). I also tried to use
pyFoamPlotRunner.py icoFoam
. But, both of these only give terminal outputs and no plots.
So, to sum up:
gives these output:
https://pastebin.com/iKqkDD07
gives these output:
https://pastebin.com/nzJPPzCr
I see no plot outputs popping up. I am on Arch Linux and also tried to switch Desktop Environment to see if it helps, still didnt get any plots.
Also, i made sure that my
gnuplot
command works.
Any help is appreciated.
manle0312 is offline   Reply With Quote
Old   August 26, 2022, 09:43
Hyun Ko
hyunko is on a distinguished road
Do you use openfoam10?
In OF10, I have a same issue for PyFoam.
hyunko is offline   Reply With Quote
Old   August 29, 2022, 04:19
Assistant Moderator
Bernhard Gschaider
Trigger warning: this posting may contain sarcasm. Don't read if you find that disturbing
Yeah. It is OF10
PyFoam needs to the detect the current time to do the plotting. For the last 20 years OF printed out the time in this format
Time = 42
Now it seems that the Foundation found out that one of the major problems that made using OpenFOAM hard was that people thought this might 42 years. So it seems that they changed it to
Time = 42s
to make things easier for the user. Unfortunately the extra "s" means that PyFoam doesn't recognize it as Time and therefore doesn't plot anything
As a temporary fix you can create a file ~/.pyFoam/pyfoamrc.d/of10.cfg with the content
[SolverOutput]
timeregexp: ^(Time =|Iteration:) (.+)s$
This makes PyFoam recognize the time format of OF10 but breaks it for all distros that value backwards-compatibility (and also OF9 and earlier)
For the next PyFoam-version I'll hardcode a time-expression that
- works for older versions (because I think that backwards-compatibility is courtesy towards the user)
- recognizes the alternate format
- does not accept everything that has "Time =" in it as a valid time (this is the hard part because there are outputs like "ExecutionTime =" that should not fit)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 29, 2022, 07:52
Hyun Ko
Thanks for your kind explanation.
