Vorticity contour
Old   July 21, 2022, 02:57
Default Vorticity contour
Anirban Kisku
anirbankisku is on a distinguished road
How to draw vorticity contour on openFOAM / Paraview?
anirbankisku is offline   Reply With Quote
Old   August 2, 2022, 05:07
sudo_rm is on a distinguished road
Just run the postProcess command to calculate the vorticity e.g:
simpleFoam -postProcess -func vorticity
https://doc.cfd.direct/openfoam/user...processing-cli
Afterwards you should be able to select it in ParaView and plot as you like.
Hope that helps,
sudo_rm is offline   Reply With Quote
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
