July 19, 2022, 11:29 |
massSource of specie i into the domain
Mario Zuber
Rep Power: 8 |
Hello all,
I am attempting to add a massSource term via fvModels to my domain. This massSource term is to be of the specie O2. My inlet is of specie CH4 at 2e-8 kg/s. The entire domain, inlet, wall BC are all at 1273 K). Chemistry/combustion is turned off I run into issues when I add O2 as a massSource term. I currently have it set up like this within fvModels: Code:
massSource { type massSource; selectionMode all; massFlowRate 4e-8; fieldValues { O2 1.0; CH4 0.0; H2O 0.0; CO2 0.0; CO 0.0; H2 0.0; T 1273; U (0 0 0); } } 1. The temperature increases up to 20 K in the domain 2. The mass balance, nor the mass fractions are correct. For one, one should expect Y_CH4 = 0.33 but it is equal to 0.38. Also the total mass at the outlet is 6.7e-8 (determined via Calculator>ExtractBlock>IntegrateVariables with equation 'U_X*p*0.016/8.314/T*CH4+U_X*p*0.032/8.314/T*O2'). The CH4 component=1.57e-8, and the O2 component=5.14e-8. The CH4 component results in a mass fraction of 0.23 which doesn't match the 0.38 taken from the contour plot, so leads me to believe I may be doing something wrong here as well. EDIT UPDATE: when using postProcess -func "patchFlowRate(name=outlet, patch =outlet)" -latestTime, I get the correct 6e-8 value at the outlet for phi. So something in the logic to get 6.7e-8 was wrong. It's important to note that I do not run into these issues when I select CH4 as the massSource. Then the mass balance is correct and there are no temperature fluxes. My thought is that it has something to do with the mass fractions and how this is interpreted as a source. Am I overlooking something, are my selected parameters even possible? Other info - openfoam9 - reactingFoam solver - laminar - cylindrical domain modeled as axisymmetric (i.e. wedge) - thermophysicalProperties (perfectGas) - default species is AR (i.e. argon). Changing the default specie has no effect - a massSource value smaller than the inlet value has no effect - forcing the U to be equal to the cell's current value (i.e. not zero) has no effect First post on here, so let's see how it goes, all help is appreciated Last edited by NuclearLeaf; July 20, 2022 at 13:12. Reason: new information, namely patchFlowRate |
July 21, 2022, 09:08 |
Mario Zuber
Rep Power: 8 |
When I switch the transport type from sutherland to const this effect went away.
That is, the mass fraction at the outlet is 0.33 as expected. So the mass fraction and mass balance (see 'EDIT UPDATE') are resolved. I still see a temperature increase of roughly 100 K. Is this really enthalpy of mixing, even though I have ideal gases? I need to do some more research into the reason behind both effects but thought I'd share for now Last edited by NuclearLeaf; July 22, 2022 at 08:40. |
July 25, 2022, 11:24 |
Mario Zuber
Rep Power: 8 |
okay, so I totally misinterpreted the fieldValues of massSource
A field value of T=1273 K implies an energy source addition equivalent to the current cell at 1273 K. So if that cell contains CH4 this energy source is for CH4 and not the O2 mass source. For now, to fix this problem, as I'm dealing solely with O2 I made and edited a new 'o2Source' file to ensure I add an energy source equivalent to O2 at 1273 K wishing my coding skills were better right about now... |
fvmodels, masssource, openfoam, species |
FOAM FATAL IO ERROR: Unknown rhoThermo type | rupak504 | OpenFOAM Running, Solving & CFD | 1 | November 22, 2021 01:40 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 21:05 |
