snappyhexmesh not create cellZone
Old   July 14, 2022, 17:47
Question snappyhexmesh not create cellZone; for dynamicMesh
MudaMuda is on a distinguished road
Hi guys, would be super apprecitae if someone can give a help here
I tried to create cellzone and facezone with snappyhexmesh in order to run dynamic mesh, like rotatingFanInRoom case did. But it didn't create one and I didn't find the reason
Here is how the SHM looks: I created a AMI using searchableBox, and tried to define the cellZone with refinementSurfaces:
geometry
    FRCfull.stl
     	type triSurfaceMesh;
        name bridge;
    busfull.stl
        name bus;
    AMI
     	type searchableBox;
        min (39.5 188675 692);
        max (44.7 188682 747);
refinementSurfaces
     	bridge
            // Surface-wise min and max refinement level
            level (7 7);
            patchInfo
                type wall;
        bus
            level (7 7);
       patchInfo
             	type wall;
	AMI
            level (7 7);
            faceType  boundary;
            cellZone  motioncell;
            faceZone  motionface;
            cellZoneInside  inside;
            //insidePoint (41.1 188680 731);
Then, createPatch was used as well. But checkMesh showed:
Mesh stats
    faces:            244567590
    internal faces:   236510331
    cells:            79390494
    faces per cell:   6.0596414
    boundary patches: 19
    point zones:      0
    face zones:       1
    cell zones:       1
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 2
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
  <<Writing region 0 with 79273836 cells to cellSet region0
  <<Writing region 1 with 116658 cells to cellSet region1
The cellZone did not created. Also moveDynamicMesh showed:
--> FOAM FATAL ERROR:
Unable to find cellZone motioncell.  Valid cellZones are:0()
anyone could give me any suggestion? thx
MudaMuda is offline   Reply With Quote
cellzones, snappyhexmesh
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[snappyHexMesh] SHM doesn't create cellZones for one region Eko OpenFOAM Meshing & Mesh Conversion 10 January 24, 2018 03:03
[snappyHexMesh] snappyHexMesh does not create mesh in body volume Illmatic OpenFOAM Meshing & Mesh Conversion 1 July 11, 2016 22:35
[snappyHexMesh] How to create internal boundaries using snappyHexMesh robyTKD OpenFOAM Meshing & Mesh Conversion 2 October 19, 2014 10:57
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
