Inlet setting of k epsilon with velocity profile OpenFOAM |
hsin
Rep Power: 5 ![]() |
I use the RANS k-epsilon model to simulate the wind field. The velocity of the inflow uses the velocity profile by csv file. k epsilon depends on speed, I also set k epsilon profile by csv file as inflow, but it's failed. This is an error message and setting file: setting&error message.zip Thanks romney |
Al Csc
Rep Power: 8 ![]() |
Have you tried commenting out (//):
#includeEtc "caseDicts/setConstraintTypes" ? Since I saw you do not have it for U Cheers |
#3 | |
hsin
al.csc Thanks for your response. I already commented out it. 1.JPG There should be no problem with U(i guess?) because the error message appears when k is calculated...? 2.JPG romney |
Al Csc
I meant in k
hsin
I commented out this in k & epsilon also
#includeEtc "caseDicts/setConstraintTypes" the error message is still the same... --> FOAM FATAL IO ERROR: (openfoam-2012) Unexpected EOF while reading dictionary entry file: /home/user/hsin/new2d(changeturbulentdepend)/sample92/0/k at line 75. From static bool Foam::entry::New(Foam::dictionary&, Foam::Istream&, Foam::entry::inputMode, int) in file db/dictionary/entry/entryIO.C at line 169. FOAM exiting |
k-epsilon model, turbulent boundary, velocity boundary |
fully developed inlet velocity in openfoam | mb.pejvak | Main CFD Forum | 0 | May 17, 2019 10:15 |
UDF inlet velocity profile mismatch with Fluent | ChristineL | Fluent UDF and Scheme Programming | 15 | November 25, 2016 06:45 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
Velocity inlet boundary condition for porous medium | Chander | CFX | 3 | March 11, 2012 21:18 |
