Jigs
Rep Power: 9 ![]() |
Hi folks,
I am using simplefoam to simualte a valve. The velocity is 0.1 m/s and I am trying to visualize the flow. While doing that i was looking at pressure contour and found that the pressure at the edges at inlet are higher. What might be the problem? Attached image will help to understand more related to the problem. Thanks |
pressure, simplefoam, valve |
Pressure Inlet Boundary Conditions | Mr.Goodcat | FLUENT | 5 | June 20, 2019 01:47 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure | vinguva | OpenFOAM Running, Solving & CFD | 2 | March 7, 2016 23:46 |
Pressure Inlet: question about total pressure | I-mech | FLUENT | 0 | July 13, 2014 05:38 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
