FOAM FATAL ERROR: mesh flux field does not exist, is the mesh actually moving?
Old   June 29, 2022, 14:42
Default FOAM FATAL ERROR: mesh flux field does not exist, is the mesh actually moving?
AbhishekTAMU is on a distinguished road
FOAM FATAL ERROR:
From function const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> &Foam::fvMesh:: phi() const
in file fvMesh/fvMeshGeometry.C at line 429.
I am trying to refine mesh based on alpha.ndodecane (fuel in diesel engine) by using dynamicRefinefvMesh class and the solver used is 'interPhaseChangeDyMFoam'. But I am gettting above mentioned error every time, I run the simulation.
I am also posting the 'dynamicMeshDict' file that I have written for this simulation.
dynamicFvMesh dynamicRefineFvMesh;
// Refinement
dynamicRefineFvMeshCoeffs
// Refine every refineInterval timesteps
refineInterval 5;
// Maximum refinement level (starts from 0)
maxRefinement 4;
unrefineLevel 10;
nBufferLayers 1;
// Maximum cell limit (approximate)
maxCells 500000000;
// volScalarField to base refinement on
field alpha.ndodecane;
// Which cells to un/refine: based on point values (simple averaging).
// - refine pointCells of point value inbetween minLevel..maxLevel
// - unrefine pointCells that are within nBufferLayers of points marked
// for refinement.
//minLevel 0.0;
//maxLevel 0.8762;
lowerRefineLevel 0.001;
upperRefineLevel 0.999;
// Fluxes to adapt. For newly created faces or split flux
// gets estimated from an interpolated volVectorField ('velocity')
// First is name of the flux to adapt, second is velocity that will
// be interpolated and inner-producted with the face area vector.
correctFluxes
(phi U)
(nHatf none)
(rhoPhi none)
(ghf none)
// Write the refinement level as a volScalarField
dumpLevel true;
Can anyone help me know the reason of this error and if the inputs in 'dynamicMeshDict' are correct or not.
AbhishekTAMU is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
