June 8, 2022, 07:59 |
codeStream cannot perform
mill
Rep Power: 5 |
Hi, All
I want to set denisty varying with depth. I use codeStream in the 0/alpha.water.org.Then I meet this error ,how can I fixed this problem. Code:
Using #codeStream at line 18 in file "/home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/0/alpha.water" Using #codeStream with "/home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_fa6bcb9352550c3007ffd513d48777a6a88042f2.so" Creating new library in "dynamicCode/_fa6bcb9352550c3007ffd513d48777a6a88042f2/platforms/linux64GccDPInt32Opt/lib/libcodeStream_fa6bcb9352550c3007ffd513d48777a6a88042f2.so" "/home/zhang/OpenFOAM/OpenFOAM-9/etc/codeTemplates/dynamicCode/codeStreamTemplate.C" "/home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/dynamicCode/_fa6bcb9352550c3007ffd513d48777a6a88042f2/codeStreamTemplate.C" Invoking "wmake -s libso /home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/dynamicCode/_fa6bcb9352550c3007ffd513d48777a6a88042f2" wmake libso /home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/dynamicCode/_fa6bcb9352550c3007ffd513d48777a6a88042f2 ln: ./lnInclude wmkdep: codeStreamTemplate.C Ctoo: codeStreamTemplate.C ld: /home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/dynamicCode/_fa6bcb9352550c3007ffd513d48777a6a88042f2/../platforms/linux64GccDPInt32Opt/lib/libcodeStream_fa6bcb9352550c3007ffd513d48777a6a88042f2.so codeStream : dictionary:"/home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/0/alpha.water" master-only-reading:0 on processor 0 have masterSize:181672 and localSize:181672 on processor 0 after waiting: have masterSize:181672 and localSize:181672 Opening cached dictionary:"/home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_fa6bcb9352550c3007ffd513d48777a6a88042f2.so" codeStream : dictionary:"/home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/0/alpha.water" master-only-reading:0 --> FOAM FATAL IO ERROR: expected keyword 'uniform' or 'nonuniform', found codeInclude file: /home/zhang/OpenFOAM/zhang-9/run/ISWtp24Exchange_con/0/alpha.water from line 15 to line 35. From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int] in file /home/zhang/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/Field.C at line 218. FOAM exiting the code is Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField #codeStream { } codeInclude #{ #include "fvCFD.H" #}; codeOptions #{ -I$(LIB_SRC) / finiteVolume / lnInclude -I$(LIB_SRC) / meshTools / lnInclude #}; codeLibs #{ -lmeshTools \ -lfiniteVolume #}; code #{ // const IOdictionary& d = static_cast<const IOdictionary&>(dict); const fvMesh& mesh = refCast<const fvMesh>(d.db()); scalerField alpha(mesh.nCells(), 0); scaler h1 = 0.24;// scaler h2 = 0.4;// scaler ht = 0.48;// scaler delta = 0.01;// forAll(alpha,i) { const scaler x = mesh.C()[i][0]; const scaler y = mesh.C()[i][1]; const scaler z = mesh.C()[i][2]; if (x <= 0.4) { alpha[i] = 0.5 - 0.5*tanh(( -ht + y + h1)/delta); } else { alpha[i] = 0.5 - 0.5*tanh(( -ht + y + h2)/delta); } } //alpha.write();// writeEntry(os, "",alpha); #}; } } boundaryField { leftWall { type zeroGradient; } rightWall { type zeroGradient; } lowerWall { type zeroGradient; } upWall { type zeroGradient; } defaultFaces { type empty; } } // ************************************************************************* // |
July 8, 2022, 09:55 |
Mark Olesen
Rep Power: 40 |
You have a stray '}' that will be a problem.
For this type of setup, it would make much more sense to use setFields or setExprField as a pre-processing step. |
July 10, 2022, 23:28 |
#3 | |
mill
Rep Power: 5 |
Thank you! |
codestream;setfields |
OF9, Error after #codeStream internalField | Dicanic | OpenFOAM | 18 | July 13, 2024 11:16 |
CodeStream Error | EzgiCFD | OpenFOAM Running, Solving & CFD | 0 | January 31, 2022 13:38 |
PROBLEMS DEFINING A LIST USING #CODESTREAM !! Help please !! | angatri_14 | OpenFOAM Programming & Development | 1 | August 21, 2020 17:16 |
Read .csv ffile in codeStream | Akshay_11235 | OpenFOAM Running, Solving & CFD | 0 | December 22, 2018 19:02 |
How to create the internalField with #codeStream | chun | OpenFOAM Running, Solving & CFD | 3 | May 6, 2017 10:35 |
