Please tell me about openFoam (not being able to see the fluid). |
June 1, 2022, 03:15 |
Issei Omura
Rep Power: 4 |
Thank you all for your help. My name is Issei and I have been studying openfoam since last month.
The version I am currently using is openfoam-v2112. I am trying to check the movement of fluid in a cylinder that moves back and forth like a piston. The solver is using pimple(DyM)Foam and the dynamicInkJetFvMesh is reproducing the motion of the piston. The motion is ideal, but I am having trouble confirming the flow in the cylinder. I would think that the piston movement would create some flow, but I cannot confirm any such flow, and it seems as if there is no fluid in the cylinder. I would like to know if there is any possible cause as to why the fluid cannot be confirmed. I am attaching the stl I created, a photo of the flow velocity after 5 seconds, and a video of the results. stl.jpg clip.jpg https://drive.google.com/file/d/1ZxD...ew?usp=sharing |
fluid, openfoam, piston |
How to obtain fluid shear stress (not only wall shear stress) in openFOAM | sourav90 | OpenFOAM Programming & Development | 8 | June 27, 2023 11:03 |
QGDsolver - OpenFOAM computational framework for fluid flows based on regularized equ | mkraposhin | OpenFOAM Announcements from Other Sources | 7 | September 13, 2021 04:09 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Hypersonic Fluid Structure Interaction with openFoam? | Ay82 | OpenFOAM Pre-Processing | 0 | February 16, 2013 19:00 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
