Generate waves in 4 phase with multiphaseInterFoam |
May 16, 2022, 08:46 |
mill
Rep Power: 5 |
I am trying to slimulate two kinds of wave in a tank.In the upper,willing to use waveModel to generate Airy waves form the boundary "Inlet". 2D multiphaseFoam. The diffiulties are the alpha of air in the boundary cannot be setting correctly.waveModel will set the alpha of waterwa,Openfoam cannot set the alpha of air.There are two suitution ,the sum of alpha will >1 at part of intet,or no phase at part of inlet . How can i set the inlet in the 0/alpha.air.orig. In the next post I will add the BC-files for the 3-phase simulation. |
May 16, 2022, 08:58 |
mill
Rep Power: 5 |
alpha.air.orig
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; location "0"; object alpha.air; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { #includeEtc "caseDicts/setConstraintTypes" leftWall { type alphaContactAngle; thetaProperties ( ( waterup air ) 90 0 0 0 ( waterlow air ) 90 0 0 0 (waterup waterlow) 90 0 0 0 ); value uniform 0; } rightWall { type alphaContactAngle; thetaProperties ( ( waterup air ) 90 0 0 0 ( waterlow air ) 90 0 0 0 (waterup waterlow) 90 0 0 0 ); value uniform 1; } lowerWall { type alphaContactAngle; thetaProperties ( ( waterup air ) 90 0 0 0 ( waterlow air ) 90 0 0 0 (waterup waterlow) 90 0 0 0 ); value uniform 0; } outlet { type alphaContactAngle; thetaProperties ( ( waterup air ) 90 0 0 0 ( waterlow air ) 90 0 0 0 (waterup waterlow) 90 0 0 0 ); value uniform 0; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } inlet { //type alphaContactAngle; //thetaProperties //( // ( waterup air ) 90 0 0 0 // ( waterlow air ) 90 0 0 0 // (waterup waterlow) 90 0 0 0 //); //value uniform 0; type fixedValue; value uniform 0; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; location "0"; object alpha.waterup; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { #includeEtc "caseDicts/setConstraintTypes" leftWall { type zeroGradient; } rightWall { type zeroGradient; } lowerWall { type zeroGradient; } outlet { type zeroGradient; } atmosphere { type inletOutlet; inletValue uniform 1; value uniform 1; } inlet { type waveAlpha; U U; inletOutlet true; liquid true; value uniform 0; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; location "0"; object alpha.waterup; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { #includeEtc "caseDicts/setConstraintTypes" leftWall { type zeroGradient; } rightWall { type zeroGradient; } lowerWall { type zeroGradient; } outlet { type zeroGradient; } atmosphere { type inletOutlet; inletValue uniform 1; value uniform 1; } inlet { //type waveAlpha; type zeroGradient; value uniform 0; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; location "0"; object alpha.waterlow; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { #includeEtc "caseDicts/setConstraintTypes" leftWall { type zeroGradient; } rightWall { type zeroGradient; } lowerWall { type zeroGradient; } outlet { type zeroGradient; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } inlet { //type waveAlpha; type zeroGradient; value uniform 0; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { #includeEtc "caseDicts/setConstraintTypes" leftWall { type noSlip; } rightWall { type noSlip; } lowerWall { type noSlip; } outlet { type outletPhaseMeanVelocity; UnMean 0; alpha alpha.waterup; } inlet { type waveVelocity; //value uniform 0; } atmosphere { type pressureInletOutletVelocity; value uniform (0 0 0); } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { #includeEtc "caseDicts/setConstraintTypes" leftWall { type fixedFluxPressure; value uniform 0; } rightWall { type fixedFluxPressure; value uniform 0; } lowerWall { type fixedFluxPressure; value uniform 0; } outlet { type fixedFluxPressure; value uniform 0; } inlet { type fixedFluxPressure; value uniform 0; } atmosphere { type totalPressure; p0 uniform 0; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "constant"; object waveProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // origin (0 0.55 0); direction (1 0 0); waves ( Airy { length 0.9; amplitude 0.01; phase 0; angle -45; } ); UMean (0 0 0); //scale table ((1200 1) (1800 0)); //crossScale constant 1; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.air 1 volScalarFieldValue alpha.waterwa 0 volScalarFieldValue alpha.waterup 0 volScalarFieldValue alpha.waterlow 0 volVectorFieldValue U (0 0 0) ); regions ( boxToCell { box (0 0 0) (5 0.2 0.1);//塌陷区,参数1 fieldValues ( volScalarFieldValue alpha.waterlow 1 volScalarFieldValue alpha.waterup 0 volScalarFieldValue alpha.air 0 volScalarFieldValue alpha.waterwa 0 ); } boxToCell { box (0 0.2 0) (0.4 0.48 0.1);//塌陷区,参数2 fieldValues ( volScalarFieldValue alpha.waterlow 0 volScalarFieldValue alpha.waterup 1 volScalarFieldValue alpha.air 0 volScalarFieldValue alpha.waterwa 0 ); } boxToCell { box (0.4 0 0) (5 0.4 0.1); fieldValues ( volScalarFieldValue alpha.waterlow 1 volScalarFieldValue alpha.waterup 0 volScalarFieldValue alpha.air 0 volScalarFieldValue alpha.waterwa 0 ); } boxToCell { box (0.4 0.4 0) (5 0.48 0.1); fieldValues ( volScalarFieldValue alpha.waterlow 0 volScalarFieldValue alpha.waterup 1 volScalarFieldValue alpha.air 0 volScalarFieldValue alpha.waterwa 0 ); } boxToCell { box (0 0.48 0) (5 0.55 0.1); fieldValues ( volScalarFieldValue alpha.waterlow 0 volScalarFieldValue alpha.waterup 0 volScalarFieldValue alpha.air 0 volScalarFieldValue alpha.waterwa 1 ); } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object setWavesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // alpha alpha.waterwa; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default CrankNicolson ocCoeff { type scale; scale linearRamp; duration 0.1; value 0.9; }; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss linear; div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "alpha.*" { nAlphaSubCycles 4; cAlpha 3; nAlphaCorr 3; nAlphaSubCycles 1; MULESCorr yes; nLimiterIter 3; alphaApplyPrevCorr yes; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; minIter 1; } "pcorr.*" { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-05; relTol 0; smoother GaussSeidel; } tolerance 1e-05; relTol 0; maxIter 100; } p_rgh { solver GAMG; tolerance 1e-07; relTol 0.05; smoother GaussSeidel; } p_rghFinal { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-07; relTol 0; nVcycles 2; smoother GaussSeidel; } tolerance 1e-07; relTol 0; maxIter 20; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-08; relTol 0.01; nSweeps 4; } UFinal { $U; tolerance 1e-08; relTol 0; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 3; nNonOrthogonalCorrectors 2; //pRefCell 0; //pRefValue 0; } relaxationFactors { equations { ".*" 1; } } // ************************************************************************* // |
September 14, 2023, 18:09 |
did you find a solution?
Sarah Aguiar
Rep Power: 3 |
Hey, did you find a solution? I'm having the same problem and don't know what to do.
waves multiphaseinterfoam |
3 phase multiphaseInterFoam | kaaja | OpenFOAM Running, Solving & CFD | 4 | March 6, 2021 13:33 |
multiphaseInterFoam vs multiphaseEulerFoam | rahulksoni | OpenFOAM | 0 | August 11, 2017 03:14 |
How to generate second order stokes waves by interDyMFoam? | shchao | OpenFOAM Programming & Development | 2 | June 4, 2012 12:21 |
two Phase column simulation | chemeng | OpenFOAM | 3 | August 18, 2010 13:53 |
Phase segregation in multiphaseInterFoam | Tracker | OpenFOAM | 3 | May 7, 2010 05:10 |
