Derivative in multiregion
Old   May 10, 2022, 01:12
Default Derivative in multiregion
Mostafa
mostafa kareem is on a distinguished road
I solved the electric potential (phi) over fluid and solid mesh like a multi-region solver and I got continuous electric potential through coupling the two domains using iterative class ( compressible Turbulent Baffle) to set equal fluxes across interface which is used in heat transfer problems.
My question is regarding the Electric field : E = -fvc::grad(phi)
although I had continuous electric potential (phi) across interface, i failed to get a continuous electric field across the interface after taking the gradient of phi
what i did is that
in the fluid domain i solved the electric potential and then took the derivative
solve
fvm::laplacian(epsilon,phiS)
E = -1*fvc::grad(phiS);
and also i did the same in solid regions
solve
in electric field file in the zero file , i set all the boundaries to calculated
i'm asking about how the fvc::grad() can compute continous electric field (E) while computing every one on seperate mesh
Thanks in advance
mostafa kareem is offline   Reply With Quote
Old   May 15, 2022, 18:09
Mostafa
i found the solution
simply, we have main polymesh folder , fluid polymesh and solid polymesh. so , after computig the electric potential over the two seperate meshes , we do a for loop on the solid data and fluid data and assign these data to the corresponding cells in the main mesh
Old   November 16, 2023, 09:25
Default Can you please explain a little bit more to get the continuous electric field.?
Barath V R
barathravi is on a distinguished road
Hi Mostafa,
Glad that you found the solution.
Can you please explan a little bit more on the for loop.?
Like whether it has to be created in the main solver and run during every time iteration or can be used for post processing alone.?
As I am new to OpenFOAM please help me with this problem.
Thanks,
Barath
barathravi is offline   Reply With Quote
Old   November 17, 2023, 01:23
Default How to access the original polymesh in the time loop of chtMultiRegionFoam.?
Barath V R
Hi Mostafa,
Can you please help me with some idea on how to access the original polymesh in the time loop of chtmultiregionfoam to calculate the derived variables.?
Thanks,
Barath
derivative, electric field, multiregions
How to add source term and material derivative of log(T) in openFaom. idrees khan OpenFOAM Programming & Development 1 January 27, 2021 15:32
Error when calculating the second derivative using the derivative function d2dy2 mona.li Tecplot 0 July 8, 2018 15:11
Derivative of a scalar or a variable through UDF fevi84 Fluent UDF and Scheme Programming 7 February 3, 2015 22:39
Tangential derivative on curved boundary Simbelmynė Main CFD Forum 40 October 14, 2014 07:57
discontinuous second derivative new_at_this Main CFD Forum 9 April 28, 2012 17:55
