defining periodic boundary conditions to use in OpenFoam
Old   May 7, 2022, 18:49
Default defining periodic boundary conditions to use in OpenFoam
Mahdi
Mahdi_Kh is on a distinguished road
Hi everyone,
I was not sure where to put this question, but I hope to get some guidance from you.
I am converting a mesh from Fluent format to OpenFOAM. The mesh was originally created in ICEMCFD. For Fluent, we can define an "interface" boundary in the ICEMCFD for the boundaries we wish to use as periodic, and then change them to periodic inside the Fluent. I am not sure this step will be valid if at the end, I convert the mesh to OpenFOAM mesh, because the "interface" boundary is not recognized in the OpenFOAM I guess.
Have you had the experience of creating a mesh with periodic BC in ICEM and converting it to OpenFOAM?
I appreciate any comment and lead.
Thank you.
Mahdi_Kh is offline   Reply With Quote
Old   May 8, 2022, 13:07
Mahdi
I think I just needed to add "neighbourPatch". It is fixed now.
Thank you all.
Old   September 1, 2023, 07:20
Kasper
KasperWayne is on a distinguished road
Hello.
Do you remember where you added the `neighbourPatch`? Did you add it directly in the .msh file or did you change the boundary conditions in the `boundary` file?
KasperWayne is offline   Reply With Quote
icemcfd, mesh, openfoam
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
