May 2, 2022, 06:06 |
interFoam crushes with sanppyHexMesh
Livia Adinolfi
Rep Power: 9 |
Hi foamers,
I am running a simulation with OpenFoam v.9 to model the overflow of an embankment with the solver interFoam and RAS k-omegaSST. My final aim is to calculate the wallShearStress along the embankment slope, when the breaching process of the embankment has started and some soil blocks have collpased resulting in a irregular stepped embankment profile. The case I have implemented is very similar to the Spillway tutorial. (https://wiki.hpc.ntnu.no/display/hpc...llway+Tutorial) To generate the geometry I tried two approaches: 1) blockMesh with spline edges to draw the "stepped" profile; 2) snappyHesMesh where I have created the .stl file in FreeCAD 3D. The structure of the two cases is the same for all the other dictionaries and for the Boundary Conditions. However, when I run the first simulation for the first case everything seems to be fine and I have a solution. Instead, in the second case the simulation crushed and I got the following error: -------------------------------------------------------------------------------------- Starting time loop Courant Number mean: 3.61123e-05 max: 0.00210365 Interface Courant Number mean: 0 max: 0 deltaT = 0.000119998 Time = 0.000119998 smoothSolver: Solving for alpha.water, Initial residual = 9.65983e-07, Final residual = 9.65983e-07, No Iterations 0 Phase-1 volume fraction = 0.077085 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.077085 Min(alpha.water) = 0 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0493387, No Iterations 10 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? at tensorField.C:? #4 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" #5 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" #6 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" Floating point exception (core dumped) -------------------------------------------------------------------------------------- Can anyone help me to understand what this error means and why this happens ? Thank you all for yuor help |
May 13, 2023, 09:08 |
Danila Aleksandrov
hello, I've got the same problem, i try to culculate hull recictance,
I take DTChull case fom tutorials and just insert my STL, then littlebit fix topoSetDicts. after a several itertions like 1000 the solution is crushing. Please, if u solve the problem, give me a hand. P.S. sorry for my eng and thank for any help |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 16:26 |
Question about interFoam Solver | Kahnbein.Kai | OpenFOAM Running, Solving & CFD | 2 | August 26, 2019 16:36 |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 17:36 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 06:58 |
Problem of InterFoam with LES SpalartAllmarasIDDES | keepfit | OpenFOAM | 3 | August 29, 2013 12:21 |
