CyclicAMI boundary problem on turbomachinary about the matching of interface |
April 15, 2022, 05:42 |
MrXuxu
Rep Power: 7 |
Hello everythone,
I meet a problems about cyclicAMI for it is required to have the same topology or geometry betwwen two meshes.But in reality,the interface of impeller is smaller than the face of volute as you can see the photos below.And then I turn to the SpaceClaim which is a 3D model designer,but it's still difficult to project the lines to the another face. At Here, I want to know whether it is a prefect way to solve this kind of interface matching problem. IMG of Impeller: IMG of Volute : I will appeciate it if you can give me a hand! BTW:in the attachment,thers are some files,including the four GEOs which I used. Memorise Best Wish Attachment: https://github.com/MemoriseXuxu/QA Last edited by Memorise; April 15, 2022 at 05:44. Reason: the lack of photo |
April 15, 2022, 11:13 |
Niels Nielsen
Rep Power: 27 |
You should really make them fit top to bottom to get a good interface.
It does not matter that the physical height doesn't match, just that the interface does. I opened in Salome and the circumferential lines are matching just fine
Linnemann PS. I do not do personal support, so please post in the forums. |
April 15, 2022, 11:28 |
Niels Nielsen
Rep Power: 27 |
Just a small heads-up.
Your faces just near the tongue are poorly defined and difficult to mesh.
April 17, 2022, 03:30 |
MrXuxu
Rep Power: 7 |
Thank you,linneman!
Is it possible to create a boundary type that makes it like the Inferface in commerical codes? By now, I need to go to the 3D pre-processing software to make the circumferential lines projected to the volute so that I can give a name-selection of this face in the volute. When it's required to do some batch processing, we need to specify every geometry by using that way. Best Wishes! Memorise |
April 17, 2022, 03:31 |
#5 | |
MrXuxu
Rep Power: 7 |
cyclicami;turbomachinary |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 16:20 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 21:05 |
