April 9, 2022, 10:06 |
rhoSimpleFOAM - Fix an instable outlet
Rep Power: 10 |
Dear all,
I'm experiencing some issues in the convergence of a HVAC analysis. The domain is quite simple: a room with an inlet (a massflow is entering) and an outlet (external pressure condition), as in the attached picture. Furthermore, since I have a certain difference of temperature, I need to use rhoSimpleFOAM. Turbulence model kOmegaSST. The problem is that there are always instabilities that originates from the outlet. More specifically, in a single cell on the border between the outlet and a wall the velocity start to increase (from a certain iteration, 300 in this case) and then this unphysical velocity start to spread from that zone (at iteration 2500 the problematic cells are 10k). In the pictures I'm showing the threshold of velocity higher then 40m/s. Sometimes I can fix this behaviour moving the outlet surface far form the room (for example using the spheric outlet in the picture) but in this case this is not working. The mesh created with snappy has not particular problems, the boundary layer has not been completely generated in that zone, but I don’t think it is needed. I don’t ‘understandwhat is wrong… I would like to use the outlet as in the reality, placing it near the wall of the room but in this case the instabilities always occur. Here are my boundary conditions, are they correct? Thanks! WalterlW U: Code:
inlet { type flowRateInletVelocity; volumetricFlowRate 5.833; value uniform (0 0 0); rho rho; rhoInlet 1.042; } outlet { type pressureInletOutletVelocity; value $internalField; inletValue uniform (0 0 0); } walls { type noSlip; } p Code:
inlet { type fixedFluxPressure; value $internalField; } outlet { type fixedValue; value $internalField; } walls { type zeroGradient; } T Code:
inlet { type fixedValue; value uniform 351.25; } outlet { type zeroGradient; } walls { type zeroGradient; } |
April 11, 2022, 04:58 |
Rep Power: 12 |
I have a suspicion what is wrong.
Can you create two plots for the inlet? 1. average pressure over iterations 2. average density over iterations |
April 13, 2022, 07:31 |
Rep Power: 10 |
Hi, thanks for the reply.
Attached are the plots of area average of velocity, density and pressure on both inlet and outlet. I also plotted the min and maximum values. WalterW |
April 26, 2022, 07:58 |
Rep Power: 12 |
sorry for the late reply. Actually the plots do not show what I expected. I thought the problem was a constant pressure-density osciallation at the inlet which then led to instability. Can you show your fvSchemes file? I suppose you use a limited scheme for div(phi, U) ? |
twoPhaseEulerFoam bubble column crashes due to problems at outlet region | hester | OpenFOAM Running, Solving & CFD | 5 | July 21, 2024 08:19 |
Correct way to fix reverse flow at outlet | Dreoasteh | OpenFOAM Running, Solving & CFD | 14 | August 15, 2023 04:56 |
How to unserstand Correct boundary condition at outlet for incompressible flow? | aja1345 | FLUENT | 3 | July 16, 2018 12:12 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 06:56 |
Generating water waves - backflow at the outlet | Luke92 | CFX | 1 | November 18, 2017 05:27 |
