April 4, 2022, 12:27 |
Issues with pyFoamPlotRunner.py Utility
Alexander Perez
Rep Power: 6 |
Im using a docker image with pyfoam, openfoam7 and swak4Foam preinstalled, the specific image is a training container for swak and pyfoam which I got from the following link https://hub.docker.com/r/bgschaid/openfoam_by_ansible
The error shown in the code below happens after trying to run the pyFoamPlotRunner.py utility I also have had to run all commands with sudo since I'm getting access denied. I was able to use pyFoamCloneCase.py and pyFoamPrepareCase.py, any suggestions would be great. Code:
(OF:7-Opt) openfoam@99b0c0aa4309:/test/01baseCase$ sudo pyFoamPlotRunner.py --clear --progress --auto --hardcopy --prefix=firstRun auto PyFoam WARNING on line 381 of file /usr/local/lib/python3.6/dist-packages/PyFoam/Applications/PyFoamApplication.py : $WM_PROJECT_VERSION unset. PyFoam will not be able to determine the OpenFOAM-version and behave strangely Clearing out old timesteps .... Warning in /usr/local/bin/pyFoamPlotRunner.py : Replacing solver 'auto' with buoyantPimpleFoam in arguments PyFoam WARNING on line 42 of file /usr/local/lib/python3.6/dist-packages/PyFoam/Infrastructure/ServerBase.py : No certficate file /home/dockeruser/.pyFoam/foamServerCertificate.cert exists. Therefor no SSL-connection for the FoamServer possible To generate a private key: openssl genrsa -out /home/dockeruser/.pyFoam/foamServerCertificate.key 2048 Then generate the cerificate that is valid for 3 years with openssl req -new -x509 -key /home/dockeruser/.pyFoam/foamServerCertificate.key -out /home/dockeruser/.pyFoam/foamServerCertificate.cert -days 1095 Killing PID 1320 PyFoam WARNING on line 292 of file /usr/local/lib/python3.6/dist-packages/PyFoam/Execution/FoamThread.py : Process 1320 was already dead Getting LinuxMem: [Errno 2] No such file or directory: '/proc/1320/status' (OF:7-Opt) openfoam@99b0c0aa4309:/test/01baseCase$ gnuplot: unable to open display '172.28.130.146:0' gnuplot: X11 aborted. gnuplot: unable to open display '172.28.130.146:0' gnuplot: X11 aborted. gnuplot: unable to open display '172.28.130.146:0' gnuplot: X11 aborted. |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
Noise postprocessing utility setup | RFlamm | OpenFOAM Post-Processing | 5 | July 30, 2018 11:06 |
wallHeatFlux Calculation wrt utility version | ahmet | OpenFOAM Post-Processing | 1 | December 18, 2016 20:45 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 17:47 |
Multigrid Stability Issues | ThomasHermann | SU2 | 1 | November 5, 2014 17:18 |
