errors installing OpenFOAM 2.4.x on Ubuntu 24.04 |
S Abrahams
Rep Power: 4 ![]() |
I'm trying to install OpenFOAM2.4.x to use interThermalPhaseChangeFoam (https://github.com/ElsevierSoftwareX/SOFTX-D-16-00038). I already have OpenFOAM9 installed successfully.
I've set up the asliases as described here: https://www.cfd-online.com/Forums/bl...vironment.html I've attached the log file for the OpenFOAM 2.4.x installation. The first error is: Code:
-- Sources for CGAL component library 'CGAL_Core/CMakeLists.txt' detected CMake Error at Installation/src/CMakeLists.txt:81 (add_subdirectory): add_subdirectory given source "/home/user/OpenFOAM/ThirdParty-2.4.x/CGAL-4.6/CGAL_Core/src/CGAL_Core/CMakeLists.txt" which is not an existing directory. Call Stack (most recent call first): Installation/src/CMakeLists.txt:140 (configure_component) But I was getting errors with Scotch6.0.3. I therefore copied the Scotch6.0.9 files from the ThirdParty-9 folder to the ThirdParty-2.4.x folder and changed the line in the scotch configuration file "etc/config/scotch.sh" to Code:
export SCOTCH_VERSION=scotch_6.0.9 Please let me know if I can give more information. |
Are you sure that OpenFOAM 2.4.x is compatible for Ubuntu version 24.04 ? If I'm not wrong, my answer is NO. Why don't you find compatible versions in any of Ubuntu or OpenFOAM ?
https://openfoamwiki.net/index.php/I...M-2.4.x/Ubuntu Thank you |
S Abrahams
Thank you for your reply.
I didn't realise that it wasn't compatible with Ubuntu 24.04. I'll see if I can find a way to use a different version of OpenFOAM or Ubuntu. |
S Abrahams
I assume OpenFOAM 2.4.0 is also not compatible with Ubuntu 24.04?
Yes true. OF 2.4.0 is compatible for Ubuntu versions till 16.04
S Abrahams
Thank you for the information
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Prolem installing OpenFOAM Ver 2.3.0 source in Ubuntu 13.1.0 on VMware | zandi | OpenFOAM Installation | 5 | March 31, 2014 03:57 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 | wyldckat | OpenFOAM Installation | 14 | February 12, 2013 04:43 |
