errors installing OpenFOAM 2.4.x on Ubuntu 24.04 |
S Abrahams
Rep Power: 4 ![]() |
I'm trying to install OpenFOAM2.4.x to use interThermalPhaseChangeFoam (https://github.com/ElsevierSoftwareX/SOFTX-D-16-00038). I already have OpenFOAM9 installed successfully.
I've set up the asliases as described here: https://www.cfd-online.com/Forums/bl...vironment.html I've attached the log file for the OpenFOAM 2.4.x installation. The first error is: Code:
-- Sources for CGAL component library 'CGAL_Core/CMakeLists.txt' detected CMake Error at Installation/src/CMakeLists.txt:81 (add_subdirectory): add_subdirectory given source "/home/user/OpenFOAM/ThirdParty-2.4.x/CGAL-4.6/CGAL_Core/src/CGAL_Core/CMakeLists.txt" which is not an existing directory. Call Stack (most recent call first): Installation/src/CMakeLists.txt:140 (configure_component) But I was getting errors with Scotch6.0.3. I therefore copied the Scotch6.0.9 files from the ThirdParty-9 folder to the ThirdParty-2.4.x folder and changed the line in the scotch configuration file "etc/config/scotch.sh" to Code:
export SCOTCH_VERSION=scotch_6.0.9 Please let me know if I can give more information. |
[OpenFOAM.com] Installing OpenFOAM 2.4.0 on Ubuntu 20.04 for Windows | RKyle | OpenFOAM Installation | 5 | January 25, 2022 10:45 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
[OpenFOAM.org] Installing OpenFOAM 2.3.x on Ubuntu 14.04 | samiam1000 | OpenFOAM Installation | 4 | January 26, 2015 02:44 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Gettings started after installing OpenFOAM 2.1.1 in Ubuntu 12.10 | yoddha24 | OpenFOAM | 7 | November 22, 2012 11:46 |
