March 21, 2022, 02:34 |
Implementation of filters in OpenFOAM
Siddhi
Hello all.
I am currently working on OpenFOAM and have few questions regarding how filters are used in it: (1)In dynamicKEqn.C, why simplefilter is again used after using filter while calculating LL,MM etc. This has not been specified in any literature. const volSymmTensorField LL ( simpleFilter_(dev(filter_(sqr(this->U_)) - (sqr(filter_(this->U_))))) ); const volSymmTensorField MM ( simpleFilter_(-2.0*this->delta()*sqrt(KK)*filter_(D)) ); const volScalarField Ck ( simpleFilter_(0.5*(LL && MM)) /( simpleFilter_(magSqr(MM)) + dimensionedScalar("small", sqr(MM.dimensions()), VSMALL) ) ); (2)In above code, if simpleFilter is used in LL and MM, why again it is used in numerator and denominator term while calculating Ck. (3)Is LESfilter as same as user defined filter? Can it be simpleFilter, LaplaceFilter etc? (4) If I want to filter velocity field, will the term given below will be sufficient? filter_(this->U_) Thank you so much if anyone can provide some guidance |
October 27, 2022, 04:29 |
#2 | |
exw599
Rep Power: 10 |
filtering, filters, lesfilter, openfoam, simplefilter |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 20:20 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 12:50 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
