Wall functions
Old   March 19, 2022, 05:00
Default Wall functions
Matteo
Matteo_Kamenjasevic is on a distinguished road
Hi guys,
I have a question about wall functions in Openfoam. If I create a mesh in Salome with viscous layer 2D that average yPlus is about 3 (y+ ~ 3), do I need wall function in my scripts (omega script). I found that if you set up very fine mesh than wall functions will automatically recognize it and not be activated in your simulation. Is that true? I hope I was enough clear...
Matteo_Kamenjasevic is offline   Reply With Quote
Old   March 19, 2022, 10:09
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Most probably, you don't need a wall function. Or more accurate: A wall function may introduce errors. The wall function increases the wall shearing stress, which is too low if a large y+ is used. If y+ is around unity, the simulation takes this into account automaticly. If you use it in such a case, you get a too high value of wall shear stress.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 19, 2022, 12:14
Matteo
Ok thank you for explanation but I have one more question. If there is no need for wall functions, how I can disable them. For example: there is script "nut" and on default it says "type nutLowReFunction". What I have to set, " type fixedValue; value uniform 0"?
Old   March 19, 2022, 12:26
piu58's Avatar
Uwe Pilz
OF does not reduce velocity near walls, but increases viscosity. If you have y+ around unity you may set nut to zero. Otherwise, zeroGadient may be used too.
Uwe Pilz
wall function, yplus
Ansys CFD-Post Application Error rushiCFD FLUENT 0 March 21, 2021 08:51
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 11:11
wall functions implementation besh OpenFOAM Programming & Development 0 January 1, 2013 10:14
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
