Problem on alphatWallBoilingWallFunction in conjugate heat transfer
Old   February 9, 2022, 12:36
Default Problem on alphatWallBoilingWallFunction in conjugate heat transfer
Ching Liu
qingqingliu is on a distinguished road
I am simulation boiling heat transfer in a 2D geometry using OenFOAM-v2012. Both the solid and fluid regions are simulated. I used the chtMultiRegionTwoPhaseEulerFoam.
I met a problem on the solid-liquid interface setting. When I used the compressible::turbulentTemperatureTwoPhaseRadCoupl edMixed at the solid-liquid interface. The solver works well. Now I want to use the RPI wall boiling model to simulate the boiling heat transfer. Therefore, I changed the solid-liquid interface to compressible::alphatWallBoilingWallFunction. However, this boundary condition makes the solver not running and no fatal error was shown.
Any one has suggestions on the solid-liquid interface setting about RPI wall boiling?
qingqingliu is offline   Reply With Quote
conjugate heat transfer, rpi wall boiling
Convergence in a conjugate heat transfer problem Mohamed Abdulazim FLUENT 5 March 28, 2020 16:41
fluent conjugate heat transfer problem eling FLUENT 9 October 21, 2017 11:10
Problem with conjugate heat transfer in Fluent JianT88 FLUENT 0 March 16, 2015 09:17
Transient conjugate heat transfer problem troyker FLUENT 0 June 21, 2013 04:37
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 16:41
