February 7, 2022, 13:19 |
Error with BuoyantPimpleFoam
jo jell
Dear All,
Altering the hotRoom tutorial model (tutorials/heatTransfer/buoyantPimpleFoam/hotRoom ) to conform to my own mesh I encountered an error that I do not understand. The output is asking me for radiationProperties while these dont have to be present in the turorial file, and when i add such a file another error appears. Can somebody explain what I am doing wrong? I am running openfoam esi v2112 and i am a beginner so maybe (hopefully) it is obvious. When requested I can send my total working file in a zip or something. Here is the error when I run my code: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } Reading g Reading hRef Calculating field g.h Reading field p_rgh Creating field dpdt Creating field kinetic energy K No MRF models present Radiation model not active: radiationProperties not found Selecting radiationModel none No finite volume options present #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam:perator/(Foam::tmp<Foam::Field<double> > const&, Foam::UList<double> const&) at ??:? #5 Foam::CompressibleTurbulenceModel<Foam::fluidTherm o>::nu(int) const at ??:? #6 Foam::nutkWallFunctionFvPatchScalarField::calcNut( ) const at ??:? #7 Foam::nutWallFunctionFvPatchScalarField::updateCoe ffs() at ??:? #8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() in /usr/lib/openfoam/openfoam2112/platforms/linux64GccDPInt32Opt/bin/buoyantPimpleFoam #9 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::correctNut() at ??:? #10 ? in /usr/lib/openfoam/openfoam2112/platforms/linux64GccDPInt32Opt/bin/buoyantPimpleFoam #11 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #12 ? in /usr/lib/openfoam/openfoam2112/platforms/linux64GccDPInt32Opt/bin/buoyantPimpleFoam Floating point exception (core dumped) Any suggestions are welcome! |
February 8, 2022, 04:34 |
Yann
Rep Power: 29 |
Hi Jojell,
The error is not related to radiationProperties, it occurs when the solver is about to start the time loop. You can see that by comparing your log file with the log file of the original hot room tutorial. My best bet would be that something is wrong in your boundary conditions, but it's hard to tell you more without having more details about your case. Yann |
buoyantpimplefoam, heattransfer, hotroom, openfoam |
buoyantPimpleFoam vs. Oliveira and Issa paper | MaryBau | OpenFOAM | 0 | June 25, 2018 15:00 |
buoyantPimpleFoam with thermalBaffle1D: strange temperature decrease | donQi | OpenFOAM Running, Solving & CFD | 0 | July 14, 2014 21:30 |
buoyantPimpleFoam Convergence Issues | joel.lehikoinen | OpenFOAM | 1 | December 5, 2013 15:58 |
buoyantPimpleFoam, icoPoly8ThermoPhysics and temperature dependent density | jherb | OpenFOAM Running, Solving & CFD | 0 | March 11, 2013 06:02 |
Questions about buoyantPimpleFoam and rhoPimpleFoam | Mojtaba.a | OpenFOAM Running, Solving & CFD | 6 | August 1, 2012 05:50 |
