GroovyBC warning
Old   February 3, 2022, 07:08
Default GroovyBC warning
Merlin Williams
MFWilliams is on a distinguished road
I am using GroovyBC for the first time and I am recieving some warnings which I am not sure how to rectify.
Below you can see the groovyBC inlet condition:
 inlet
        type groovyBC;
    variables "x=time();a1=3.017;b1=1.059;c1=0.421;a2=2.633;b2=1.144;c2=3.47;a3=0.08375;b3=8.396;c3=-0.2351;a4=0.06651;b4=16.76;c4=-0.6502.......";
    valueExpression "(a1*sin(b1*x+c1) + a2*sin(b2*x+c2) + a3*sin(b3*x+c3) + a4*sin(b4*x+c4)........*(-normal())";
    value uniform (0 0 0);
but whenever I run anything like 'blockMesh -region solid' or 'solids4Foam' i get the following errors:
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 124
    could not load libOpenFOAM.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    could not load libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory
I have added the necessary libraries to the control dict and the code completes but I would like to get rid of these warnings.
Please can somebody advise how to fix this problem?
Thank you for your help in advance
Merlin
MFWilliams is offline   Reply With Quote
boundary condition, groovybc, warning message
Caffa 3D code Waliur Rahman Main CFD Forum 0 May 29, 2018 01:53
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
